In that case, it's way too high. The recommended cold pressure should be ~35 PSI. First order of business should be to let some air out of all four tires. That may not solve the noise issue but you'll get a much better (and safer) ride.
I'm that case, it's way too high. The recommended cold pressure should be ~35 PSI. First order of business should be to let some air out of all four tires. That may not solve the noise issue but you'll get a much better (and safer) ride.
