Transmission fluid change part numbers
Subscribe
Mar 16, 2019 | 08:22 AM
I thought it would be a good place to document part numbers for parts needed when performing a transmission fluid change. Not all parts would be needed, but in the event of a stripped plug, or damaged pan or gasket, a part number would be nice to have. I'm not 100% sure on these part numbers, so any confirmation would be helpful. I'll update the first post as needed.
Transmission pan 35106-30260
Pan gasket 35168-60010
Filter (AWD) 35330-30080
Filter (RWD) ???
Drain plug 90341-10011 (need confirmation)
Drain plug washer 35178-30010
Level plug 90341-10021 (need confirmation)
Level plug washer 35178-30010
Fill plug ???
Fill plug washer ???
Reply 1
Mar 16, 2019 | 12:23 PM
I think the filler plug washer is rubber o ring if im remember correctly. I changed my tranny fluid long time ago. but I remember its rubber o ring I think.
Reply 0
Mar 16, 2019 | 07:28 PM
Quote: I thought it would be a good place to document part numbers for parts needed when performing a transmission fluid change. Not all parts would be needed, but in the event of a stripped plug, or damaged pan or gasket, a part number would be nice to have. I'm not 100% sure on these part numbers, so any confirmation would be helpful. I'll update the first post as needed.
Pan gasket 35168-60010 YES
Filter (RWD) 35330-50020
Filter o-ring (RWD) 90301-31014
Drain plug 90341-10011 (need confirmation) YES
Drain plug washer 35178-30010 YES
Level plug 90341-10021 (need confirmation) YES
Level plug washer 35178-30010 YES
Fill plug 90341-18059
Fill plug washer 90301-15004 rubber o-ring
See my comments/additions above in red. I ordered the parts from a local Lexus dealer though I have not actually done the work yet but my part numbers match up with yours where I put a "yes".
One comment on the fill plug "washer" which is an o-ring. The fill plug appears to be identical to the V6 Camry 2007-2011 fill plug and that gets a flat aluminum crush washer however the part Lexus had for the GS transmission is this o-ring. I don't know why but that's what it is.
Reply 0
Mar 17, 2019 | 01:40 AM
I think it would be a good idea to document which vehicle you're talking about here. I speak with no authority but my research has turned up at least 6 different transmissions in the 4GS250/350/450 range. The 2012-2013 model GS350s with the A760E 6 speed have a different gearbox to the facelifted model with the AA81E 8 speed and the AWD popular in the north has a A760H. The part # may well be the same, just thought it was worth noting. Your RWD part numbers look spot on, they match mine. It appears that I forgot to order the fill oring..dang!
I found these torque settings for the A760E
AT drain plug 20nm
AT refill 39nm
Reply 0
Mar 17, 2019 | 09:01 AM
How many miles is it recommend to change the tranny fluid? Thanks
Reply 0
Mar 17, 2019 | 02:49 PM
Quote: How many miles is it recommend to change the tranny fluid? Thanks
50000 miles is recommended, read your manual. Just do it with your major spark plug/diff services.
Reply 0
Mar 17, 2019 | 04:00 PM
Quote: 50000 miles is recommended, read your manual. Just do it with your major spark plug/diff services.
It is? You sure? Have you read your manual?
Reply 0
Mar 17, 2019 | 04:26 PM
Quote: It is? You sure? Have you read your manual?
Reply 0
Mar 17, 2019 | 04:36 PM
My 2013 GS 350 does not recommend replacement of the transmission fluid - only to inspect: 'Transmission for signs of leakage' through 150,000 miles.
Reference: 2013 GS 350 Scheduled Maintenance
Reply 0
Mar 17, 2019 | 06:11 PM
Quote: My 2013 GS 350 does not recommend replacement of the transmission fluid - only to inspect: 'Transmission for signs or leakage' through 150,000 miles.
That's rather scary. Lexus USA is doing their customers a disservice, in the notes section your service booklet states that the transmission is a sealed unit and not to be serviced.
Lexus Australia doesn't mandate auto services but they do recommend them every 75000kms. I'm only guessing but given how differently the vehicles are positioned on opposite sides of the globe, Lexus USA went with the 'sealed' angle to reduce the 'cost of ownership'.
Reply 0
Mar 17, 2019 | 06:32 PM
Quote: That's rather scary. Lexus USA is doing their customers a disservice, in the notes section your service booklet states that the transmission is a sealed unit and not to be serviced.
I have asked a few Lexus technicians if they see many high-mileage vehicles with transmission issues that did not have the transmission fluid replaced. They've all said that the number of transmission problems they see are very limited in any of the current models because the transmissions are so well designed, and transmission fluid has never been a problem regardless of mileage.
Reply 0
Mar 17, 2019 | 07:20 PM
I would wager the percentage of high mileage owners coughing up to have their old cars serviced by a Lexus dealership is pretty low. I would have paid 10% of the car's value to get it's last major service.
We could probably get good life out of the engine if we increased the oil change intervals out to 25000kms. The fact is there is old oil with broken down additives. I haven't searched through the 3GS forums but I'm sure they're having issues with their transmissions as they age - some of us share the same transmission.
Reply 0
Subscribe
