2013 Battery Replacement
Old Feb 18, 2019 | 07:50 AM
krawfo's Avatar
krawfo
Default 2013 Battery Replacement
The battery on my GS350 is dead and needs replacement. How critical is it to use a "battery memory saver" device when changing out a battery? If one is NOT used, how much of a pain is it to restore all the settings?
Old Feb 18, 2019 | 07:52 AM
np20412's Avatar
np20412
Your settings will be remembered. All you'll need to reset is the clock.
Old Feb 18, 2019 | 07:59 AM
krawfo's Avatar
krawfo
Thanks so much. That saved me a bit of aggravation.
Old Feb 18, 2019 | 08:04 AM
PsykotiK's Avatar
PsykotiK
you don't ever really need those memory savers. The most you have to do usually is input the code for the radio and maybe reset your radio stations but thats about it
Old Feb 18, 2019 | 08:29 AM
jdpdata's Avatar
jdpdata
I disconnected my battery on several occasion to install various things in my car. Sometimes for hours at a time and never had any issues other than having to reset the clock. Be advised that if you buy non OE battery, you will have to remove the sleeve. I recommend getting the Costco Interstate battery.
Old Feb 18, 2019 | 09:10 AM
BUZY3215's Avatar
BUZY3215
Just replaced mine two days ago (battery was out for about 2 hours). Only needed to reset the clock.
Old Feb 18, 2019 | 09:57 AM
krawfo's Avatar
krawfo
My Interstate battery from Costco is in and all is well. Sirius/XM fired right up. No dash warning lights lit up. My mpg and ave. speed were reset to 0 but obviously not a big deal. I decided to test out putting the battery cage back on but it was a very tight fit and the heads of the studs for the wire supports would rub on the battery case so I abandoned that plan.
Thanks everyone for weighing in.
Old Jun 26, 2022 | 02:08 AM
Nickysan18's Avatar
Nickysan18
9th Gear
Default Lost my seat settings
I had my check engine light as well as VSC light come on and my fiancé thought it smart to unplug the negative from the battery and reattach to clear the lights (which worked) but after my seat program settings and for a while even the windows (but that went back to normal sort of except you can hear the motor when you put up passenger side window) and now I lost my ability to use my seat preset and I cannot preset any radio stations is there something I can do to return my seat setting and everything else back to how it was before he did this?
Old Jun 26, 2022 | 02:38 AM
703's Avatar
703
Unplugging the battery to turn off the check engine light doesn’t do anything useful.
The check engine light will just come back on eventually as the fault which caused it in the first place is still there.
Disconnecting the battery shouldn’t disable your seating memory. But you can try moving your seat all the way forward and then all the way backward then see what happens.
Old Jun 26, 2022 | 07:15 PM
Nickysan18's Avatar
Nickysan18
9th Gear
I found a fix on YouTube actually to reset the seat memory cause unfortunately by him doing that it did cause my seat memory to not work which I’ve read a couple other people say the same thing happened to them as well and as of now I just passed an echeck and lights have not come back on it’s been about a month or so so fingers crossed nothing serious is going on as I also just got a tune up done
Old Mar 7, 2024 | 05:20 AM
Mari77's Avatar
Mari77
1st Gear
Default Car won’t stay on after removing the negative terminal to shut the alarm off
My car won’t stay on after removing the negative terminal to shut my alarm off on it. What do I do ? 2011 Lexus is 250
GudSht350
Oct 23, 2025 02:42 PM
jbone29
Aug 24, 2012 07:15 AM
Akachan LS
Maintenance
Oct 29, 2010 03:46 PM
shoffman
Sep 11, 2010 08:16 AM
Sukimo
RX - 1st Gen (1999-2003)
15
Dec 2, 2007 03:43 PM
