Please help!!! 2014 GS 350 clock running too fast!!
Old Jun 24, 2023 | 04:28 AM
  #76
bclexus's Avatar
bclexus
Originally Posted by PGA71
Even the broken clock is correct twice per day!
@PGA71 - Yeah, well - They say a man with one watch always knows the time, but a man with
two watches is never quite sure.
Old Jun 26, 2023 | 08:58 AM
  #77
bayareaemt's Avatar
bayareaemt
Originally Posted by bclexus
Don't you just glue the nylon gear to the ferrite magnet? Is the shaft supposed to be glued to something? Maybe the clock doesn't work now because the shaft is glued...
@bclexus the shaft with gear is all one tiny part. I did put tiny/micro amount of household glue and let it dry for an hour. Now magnets and plastic shaft/gear is joined together.
I also checked pictures on various post here and confirmed that the white plastic washer is also placed correctly (that never came out of that black cover).
If I remove the gear/magnet assembly then rest of clock mechanism spins very freely, with gear/magnet in place I feel resistance in spinning rest of clock mechanism. I believe that resistance is above the threshold that clock motor can handle. Clock lights up when trying to adjust time forward or backwards but doesn't run at all.
Most likely it is bricked now. I don't think I will replace it with new unit but will keep looking for some used ones come on sale for 30-40 bucks. Called local dealer and it is 300+ dollars with taxes.
Old Jun 26, 2023 | 09:07 AM
  #78
peasodos's Avatar
peasodos
Check https://www.amayama.com/ or https://www.megazip.net/ it's over $100 cheaper that USA dealers including shipping. The actual shipping is faster than what they quote, when I ordered parts arrived within a week via dhl.
Old Jun 26, 2023 | 09:19 AM
  #79
bayareaemt's Avatar
bayareaemt
@peasodos do I need to order UAE version or Japan version? Just wanted to be sure which one would fit my US 2015 GS350 AWD
Local dealer parts manager had told me that he would give get me upto 40% off but I didn't show interest on clock. I picked up oil filter, air filter, cabin filter and Toyota WS fluids plus gaskets for 40% off
Old Jun 26, 2023 | 09:50 AM
  #80
peasodos's Avatar
peasodos
There is no UAE version or Japan version, both are exactly the same made in Japan. Those are just the location it ships from. It doesn't matter what part of the world it comes from it's the same exact part number. The reason it's cheaper from UAE warehouse is because they have much more supply than the one in Japan.
The ones shipping from UAE are also listed on eBay, but slightly increased price with shipping:
https://www.ebay.com/itm/353220784520
Old Jun 26, 2023 | 12:15 PM
  #81
lexo98's Avatar
lexo98
First time I did this I bent the shaft a little bit putting it back together. I was able to bend it back and the time is right on since. Even if you think you did it right I would take it apart again and make sure everything is put together properly and that the glue didn’t squeeze out onto something else.
Old Jun 26, 2023 | 12:19 PM
  #82
bayareaemt's Avatar
bayareaemt
I opened and reassembled 3 times with no luck. Glue was put outside (a very tiny bit) and I let it completely dry for an hour after which it wasn't anymore tacky. I really doubt that glue would have touched something else.
coming weekend, I will try to look at shaft one more time, I pulled out dead straight every time so I don't think it is bent.
Old Jun 26, 2023 | 12:55 PM
  #83
jgscott's Avatar
jgscott
Mistake post, wrong thread.
Old Jun 26, 2023 | 01:50 PM
  #84
bclexus's Avatar
bclexus
Originally Posted by jgscott
I just put my car in the shop for warranty service. My pass side mirror would not go left to right. They ordered a new Actuator, installed it and it works perfect now.
@jgscott - Since your post is not about the Lexus dash clock I presume you meant for your above quoted post about your passenger side mirror to be posted in the 'What did you do to your GS today' thread, right?
You're pretty rough on your mirrors, aren't you? Didn't you just have your drivers side mirror repaired last week?
Old Jun 27, 2023 | 11:31 AM
  #85
jgscott's Avatar
jgscott
Yep good catch, confirmed I am Human.
Old Jun 27, 2023 | 07:25 PM
  #86
bclexus's Avatar
bclexus
Aren't we all?
Old Jan 21, 2024 | 09:11 PM
  #87
lexlutherclub's Avatar
lexlutherclub
1st Gear
Default Fixed mine using the "glue to magnet fix"
Took the clock apart and took apart the assembly as described in this thread. The plastic gears were completely detached from the magent, so all it took was a drop of super glue to put them back together to fix the issue. Thanks guys!
Old Feb 29, 2024 | 10:22 PM
  #88
4GS350's Avatar
4GS350
My clock was running 30-45mins fast everyday from Dec last year till a week ago.......now it suddenly runs fine......pondering whether i should take the clock apart and do the 'fix'......
Old Mar 1, 2024 | 11:06 AM
  #89
lexo98's Avatar
lexo98
Funny this comes up again. I did the fix probably over a year ago and it was right on until yesterday.
Old Mar 1, 2024 | 11:43 AM
  #90
fourgs's Avatar
fourgs
If mine would fail I would stick a Magsafe wireless phone charger on top of it seems like same diameter
