my navagation isnt calibrated correctly, I tried callibrating but after Calibration it goes out of whack all over again. Has anyone else has this type of an issue? I do have a navbypass installed could that be the issue?
A lot of folks on the IS forum mentioned having this same issue. I believe they found that the biggest culprit was that the GPS antenna was not seated properly after hacking the nav, or when having other work done that could have knocked the antenna plug loose on the back of the unit. Do you see "GPS" on the screen when the navigation appears to be off calibration? If not, there is a good chance this is the path to resolution for you.
