Little or No Deceleration while Coasting
So I've had my 2015 for 5 weeks now and I've been noticing lately that sometimes when coasting, with my foot off the gas pedal, the car seems to maintain speed 35-40 mph for several seconds before slowing further. I noticed this when approaching a traffic light and the car was taking a long time to decelerate. The car's not cold and is at normal operating temperature. My driving style right now is pretty laid laid back, while I get to know the car. The GS only has 26K miles on the odometer.
Has anyone else noticed this? Is this by design, or maybe a quirk I need to address?
Is what you say true on a slight incline?
I'm not sure...
I expected the car to slow down when there's no input to the gas pedal, but it seems the GS might be maintaining/increasing the engine idle speed to match the vehicle speed, rather than let the drop in rpm and hence engine speed naturally slow the car. If the idle is being artificially increased by the ECU when coasting, wouldn't that increase gas consumption? If that's how the car is designed to perform, then there's no problem or complaint, however if not, I'm seeing if this might be a concern.
In other cars, deceleration is instantly noticeable when getting off the gas, and I'm not talking at high speed, but laid back driving.
Not the first time I've read this, tho personally I don't notice much difference between my GS and my infiniti in this regard.
I remember another thread where someone was saying when they set cruise control but then go down a small slope the car increases speed quicker than you'd think. Others commented on how the GS has a pretty low rolling resistance and is actually quite aerodynamic.
I'm not sure...
I expected the car to slow down when there's no input to the gas pedal, but it seems the GS might be maintaining/increasing the engine idle speed to match the vehicle speed, rather than let the drop in rpm and hence engine speed naturally slow the car. If the idle is being artificially increased by the ECU when coasting, wouldn't that increase gas consumption? If that's how the car is designed to perform, then there's to problem or complaint, however if not, I'm seeing if this might be a concern.
In other cars, deceleration is instantly noticeable when getting of the gas, and I'm not talking at high speed, but laid back driving.
I use cruise control about 90% of my ride every day. You are right, if you have cruise control activated and go down a pretty decent sized down slope, it will pick up speed before braking. So if I am going 40 MPH and hit a down slope, the car will speed up to roughly 45 MPH before it starts to break to get back down to 40MPH. I think it's a built-in speed tolerance by Toyota/Lexus ECU to avoid nuisance breaking and I'm okay with that.
No Sports+ mode in my basic GS. I'm in normal mode 100% of the time. Taking it easy until I get to know the GS better.
As nice as I can say it, I think you're overthinking the car and it's operation. I'm not a race car driver or a scientist by any means but I don't really notice any more particular glide effect or rise in rpm more than just normal car dynamics. Certainly none that would affect mileage.
It'd be one thing if the car was accelerating out of control.
Car makers have designed into their engine management system certain parameters that control when fuel and engine timing is changed, mostly in an effort to increase fuel mileage. Signals are fed by the throttle position, the transmission and the brakes, as well as from speed and temperature sensors. For example (which is purely fictional), the following parameters could be designed into the engine management system: when traveling between x1 speed and x2 speed - if the throttle is closed after having been opened between 2% and 8% for > 6 seconds without applying the brakes or shifting the transmission - the vehicle will be in Coasting mode1 to purposely prevent excessive deceleration for x amount of time. However, if the brakes are engaged during this time the system changes to Coasting mode2 where fuel delivery and engine timing is changed to purposely enhance deceleration.
Different vehicles from different manufacturers over the past decade have had a wide range of small changes made in this regard that mostly go unnoticed. I would consider these habits of your car to be unique to that particular model and year, and working as the manufacturer has designed and intended it to work.
I guess I'm a bit OCD that way... but it could always be worse.
Thanks for the super-detailed, and purely fictional, response!
Before trying this experiment I honestly could not have told you what would have happened. Does it surprise me? Nope, not in the least. I like it reacting just that way. It is not significantly different from any other automatic transmission vehicles I own or have driven recently.
I did not check what gear it was in at 35-40 mph with slight throttle, but I assume it may have [even] been in 6th gear. If it was in 4th gear, or a lower gear, I would not expect the speed to be maintained as it was.
