Steering Wheel Squeak / Noises
Did you replace only clock spring Part#8430853010 , without the sensor right?Did you use Origanl Toyota Part or Aftermarket(I see some on Ebay)
I have gs 350 2013 and its a noise too....
Do I have to program computer after I replace it?
one mechanic told me we have to program computer to adjust the new Clock spring to "Zero position" is it true?
I appricieted for your quik response
You don't have to program anything unless you bugger up the removal of the spring from the steering angle sensor or don't put the steering wheel back on exactly the same way. The clock spring comes with a little clip which is for keeping something in position whilst you work.
You can calibrate zero point if you like but if your rear camera shows your guidelines as being perfectly straight then it's likely fine fine.
Alexy69
NX - 1st Gen (2015-2021)
Nov 1, 2019 09:12 AM
rocketpope
Aug 31, 2018 08:53 PM
