Interior lights 2016 models
Old Feb 1, 2017 | 07:50 PM
Luffy808's Avatar
Luffy808
Default Interior lights 2016 models
Does anyone know how to remove the front an rear dome light covers?! There is no spots or indentations to slip a flat head to pry them open! Any pics and details would be greatly appreciated. Thanks
Old Feb 1, 2017 | 11:29 PM
Nasrul3698's Avatar
Nasrul3698
Why do you wanna change it though? :O
Old Feb 1, 2017 | 11:36 PM
Luffy808's Avatar
Luffy808
I want to change the middle light to LED. I can tell it's a regular light bulb.
Old Feb 2, 2017 | 05:13 AM
imrankh24's Avatar
imrankh24
It's normal for the gs? In my es all of them are led.
Old Feb 2, 2017 | 05:29 AM
yardie876's Avatar
yardie876
Interior lights are all LED. The lights on the lower door, puddle lamps on the mirror, and trunk light are incandescent, though.
Old Feb 2, 2017 | 10:18 AM
Nasrul3698's Avatar
Nasrul3698
yeah, just change the incandescent ones
Old Feb 2, 2017 | 10:45 AM
Luffy808's Avatar
Luffy808
mostly all the lights are LED except the puddle lamps, trunk, and the very middle front and rear dome lights! I am asking kindly if anyone knows how to take off the dome lights cuz there is no spot to put a flat head anywhere to pop them open! Thanks
Old Feb 2, 2017 | 11:59 AM
dchar's Avatar
dchar
The front and rear dome lights are LED.
Old Feb 2, 2017 | 12:44 PM
DallasDave's Avatar
DallasDave
I found this that might help you:
https://www.youtube.com/watch?v=SArSvPJBGLw
I too would like to increase the output of my dome lights. I was able to get the lens off of the front dome light and it was already equipped with LED bulbs. Both seemed to be non-replaceable. Haven't figured out the rear dome yet, but there are probably mounting clips under the housing. That's how it was on my prior two vehicles. So the "lens" doesn't come off, the whole housing drops and you access the bulbs from the back of the circuit board.
Old Feb 3, 2017 | 10:47 PM
DP03's Avatar
DP03
Yup, took my front dome light apart as well only to find the same....LED, not replaceable without cutting wires I think.
To the OP, the dome light covers come out by prying from the sides. Used a plastic panel tool, but it was a PITA. And there are a couple of different layers to pry open under the cover (at least on the front one). I ended up leaving it alone....
The trunk light, on the other hand, is a 10 min bulb replacement. I put a 12 led board in that came with the adapter, plug and play. What a difference!!
Old Feb 5, 2017 | 12:55 AM
Infamous3's Avatar
Infamous3
The driver and passenger mirror lights are also regular bulbs, think they used to be LED's on the 2013-15 though
Old Feb 5, 2017 | 07:54 AM
JDR76's Avatar
JDR76
The vanity mirror lights on my '15 are incandescent.
scottone92
LX - 3rd Gen (2008-2021)
12
Aug 8, 2021 07:53 PM
tpjc1018
Jun 30, 2014 07:29 AM
datboiM
RX - 1st Gen (1999-2003)
Oct 5, 2010 09:21 AM
Nilesh
Lighting
Feb 10, 2008 03:00 PM
natnut
Lighting
Oct 12, 2006 11:29 PM
