Bosch Icon Wipers slight warning
Old Dec 11, 2016 | 09:23 AM
tknx's Avatar
tknx
Default Bosch Icon Wipers slight warning
If you decide to go aftermarket on your wipers, not that on my 2013, the recommended 28A/18B combo bump into each other when at the bottom setting causing a thump.
I just put a 26A on the driver's side to see if that works okay. If not, I'll go back to OEM / Denso wipers.
Old Dec 11, 2016 | 09:02 PM
joedaddy1's Avatar
joedaddy1
26 is the factory size
Old Dec 13, 2016 | 09:32 AM
Patrick4GS's Avatar
Patrick4GS
My local parts place told me it was 28" and 18" as well. They did the same thing and rubbed together when in use, the driver side was also close to the roof above the windshield. Switched to a 26 and all is well.
Old Dec 15, 2016 | 02:07 PM
tknx's Avatar
tknx
Yep 26 works fine.
Bosch has it wrong in their system (and so does Amazon).
Old Dec 15, 2016 | 02:12 PM
bclexus's Avatar
bclexus
The OE wipers do a pretty nice job...
Old Dec 16, 2016 | 12:03 AM
Dallasguy1's Avatar
Dallasguy1
The stock wipers do pretty Gud , u can just change the inserts if they are wore down.
Old Dec 16, 2016 | 06:03 AM
jj14's Avatar
jj14
I need to change mine - are the inserts only available at the dealership? Or can they be purchased elsewhere?
Old Dec 16, 2016 | 09:50 AM
Dallasguy1's Avatar
Dallasguy1
Dealer if not eBay is your best bet.
Old Dec 16, 2016 | 10:46 AM
Htony's Avatar
Htony
I just measure the length of blade when I replace with after market blades. Can't trust look up chart.
TrueDat96
Apr 23, 2021 07:28 PM
Speedin
IS F (2008-2014)
16
Apr 29, 2019 02:05 PM
vital
Oct 8, 2011 03:14 PM
altersail
Nov 6, 2008 02:59 PM
big lar
Aug 7, 2005 04:45 AM
