Gs350 bbk update
Old Jan 29, 2013 | 01:15 PM
mrpartsman's Avatar
mrpartsman
Default Gs350 bbk update
I just dropped off my car to Stoptech Brakes for an R&D of the front and the rear brakes, as some of u know that I had the fronts done about 4 months ago, so they gonna redo the fronts and new kit for the rear, I will keep u guys posted , I should have it by friday.
Old Jan 29, 2013 | 01:48 PM
LexFather
Guest
Posts: n/a
Dude, yes!!!!
Old Jan 29, 2013 | 02:03 PM
e39ng's Avatar
e39ng
Brembo has the GT kit for front and rear. I ordered them already...takes a few weeks to come.
Old Jan 29, 2013 | 02:14 PM
terrycs's Avatar
terrycs
What are Brembo's rotor diameters and caliper configuration?
Old Jan 29, 2013 | 02:17 PM
mrpartsman's Avatar
mrpartsman
I know they realeased it at the Aapex show. should be 6 piston front and 4 piston rear, I had mine done way before Brembo came out with it.
Old Jan 29, 2013 | 02:22 PM
terrycs's Avatar
terrycs
Do you have an F-Sport that already had the 14" front rotors from the factory?
Old Jan 29, 2013 | 02:38 PM
e39ng's Avatar
e39ng
Front: 380 x 32mm 6pot
Rear: 345 x 28mm 4pot
Old Jan 29, 2013 | 02:43 PM
mrpartsman's Avatar
mrpartsman
No I don't , but the calipers are the same on the F Sport and the rear also are the same brakes.
Old Jan 29, 2013 | 02:44 PM
sam430's Avatar
sam430
Will these fit the 19" wheels? link please. I wanna see how it looks.
Old Jan 29, 2013 | 02:57 PM
Vroomin350's Avatar
Vroomin350
Most rotors under 405mm will fit under a 19" wheel. The Gs-Fsport comes with a true 2 piece rotor (6 piston) from factory if I am not mistaken. Quite honestly I think spending money on a BBK for this car is a waste of money. But then again I probably would too for show.
Old Jan 29, 2013 | 03:00 PM
mrpartsman's Avatar
mrpartsman
it might work all depends on the offset, if I am not wrong, I tried my 18" and they are 45 offset and it does not clear, so the offset on the wheel is a big thing, and I tried my other 18" with 35 offset no problem , so it might clear, I know the brembo kit at vegas had 22" on it. so wait until e39eng gets it and get more info from there.
Old Jan 29, 2013 | 03:02 PM
mrpartsman's Avatar
mrpartsman
its a 2 pcs rotor but 4 piston caliper.
Old Jan 29, 2013 | 03:04 PM
terrycs's Avatar
terrycs
I wish they'd make them look better!
Old Jan 29, 2013 | 03:09 PM
terrycs's Avatar
terrycs
I'm confused .. so F-Sport stock calipers are 6 pot front and 4 pot rear and same as your StopTech configuration?
EDIT: Got it ... Stock F-Sport has 14" rotors and 4 pot calipers in front. So the StopTech BBK will also have 14" rotors but a 6-pot caliper up front instead.
Old Jan 29, 2013 | 03:26 PM
Vroomin350's Avatar
Vroomin350
Ok cool, I wasn't too sure about the caliper. Still, it's pretty big for a 4 piston. I think someone should try powdercoating the stock calipers, I think they would be very surprised.
