Trunk mounted taillight "Creeeaak"???
Old Oct 30, 2012 | 01:32 PM
ShawnD's Avatar
ShawnD
First world problems!!
Old Nov 27, 2012 | 06:59 PM
Daniely30's Avatar
Daniely30
Originally Posted by PLAYTYM
Opened my trunk yesterday...it was 66 degrees F and cloudy. Noticed as the trunk opened that I was hearing a very noticeable creaking sound. At first I didn't know where it was coming from, then I pushed on the trunk mounted taillights it was very obvious it was the plastic creaking against the trunk.
Has anyone else noticed this?
My right taillight creeks bad too
Old Nov 27, 2012 | 08:16 PM
Outrage's Avatar
Outrage
Here is a video I took some time ago which demonstrates this problem. It occurs at lower temperatures.
Old Nov 28, 2012 | 05:44 AM
PLAYTYM's Avatar
PLAYTYM
Mine was also my right taillight...hmmm???
Old Nov 28, 2012 | 05:46 AM
PLAYTYM's Avatar
PLAYTYM
http://www.youtube.com/watch?v=obiwwoN_BAE
That's it EXACTY!!! I also notice it's your right taillight as well. Seems to be a theme going on here???
Old Nov 28, 2012 | 11:01 PM
louisp_p's Avatar
louisp_p
Mine has the same noise and it also happens only on right taillight too....
Old Aug 20, 2013 | 06:21 PM
baseball45's Avatar
baseball45
So, does anyone know whether there is a fix?
Old Aug 20, 2013 | 06:30 PM
baseball45's Avatar
baseball45
Originally Posted by Chris8152
I have the same problem with mine, the dealership did have a quick look at it and put some sort of lubrication around the light, it solved the problem for a couple of days, but the creek soon came back with a vengeance, ill put up for it for a while and then will have to book it in for then to have another look.
Chris,
So did the dealer fix it again since it came back ?
Old Aug 20, 2013 | 08:31 PM
Very easy fix, they install some foam tape between the lamp and the trunk housing. Problem solved.
Old Aug 21, 2013 | 01:25 AM
Chris8152's Avatar
Chris8152
Originally Posted by baseball45
Chris,
Yes as mentioned above they removed the tail light and re felted it, unfortunately this only solved the problem for a week or so and the noise was back, however about a month later the squeaking disappeared and for the past 2 months it has been fine, I am just wondering if it is temperature related, I will see if it returns in the colder weather.
Old Aug 24, 2013 | 08:05 PM
Afrosheen's Avatar
Afrosheen
It's 100 degrees here today and sure enough, my right side does it too. I thought it was the hinge at first (natural, logical thing) but nope, like you guys said, it's the light assembly. Pushing on it creaks.
Since the car is a week old I figure the dealer will be glad to see me again anyway.
endo022
Nov 24, 2018 04:36 PM
nvbirdman
Mar 3, 2016 08:45 PM
shiny250
Mar 12, 2010 08:13 AM
joshoowa
14
Mar 24, 2003 08:35 PM
