2013 GS350 power issue
Old Oct 1, 2025 | 06:00 PM
aph7649's Avatar
aph7649
3rd Gear
Default 2013 GS350 power issue
I have a 2013 GS 350 and I'm having power issues, would appreciate any advice or knowledge anyone can share.
Short version - replaced battery, dash lights come on once connected, when I try to start it all goes black and no power at all
Longer version
I replaced the battery in my GS back in April - it appeared to take it just fine, started up, etc. For various reasons, I let it sit for a while and when I tried to start up again I couldn't get it going without a jump. I could jump it, drive somewhere, park it overnight, and in the morning it would be dead again. I put it off for a few months but finally this week I took the battery back to autozone to have it checked. Battery determined to be bad so they gave me a replacement.
I just installed the replacement battery and it appeared to be working - all the lights came on, the dash lit up, it appeared ready to start. But when I tried to start it everything just went black. All the lights turned off and pushing the start button does nothing. I tried disconnecting the battery and reconnecting and the exact same thing happened again.
Any clue what's going on? The battery is good so I assume there's some other electrical issue, but no idea where to start or what it is (I'm not knowedgeable). Thanks for any help.
Old Oct 1, 2025 | 06:36 PM
jgscott's Avatar
jgscott
What is the exact stock number type of the Autozone battery you got?
Old Oct 1, 2025 | 06:46 PM
JeffKeryk's Avatar
JeffKeryk
Use your volt meter to see the battery condition or take it in to be tested.
Put your jump box on and see what happens.
Sounds like a poor connection, possible from a corroded terminal?
Good luck.
Old Oct 1, 2025 | 07:42 PM
aph7649's Avatar
aph7649
3rd Gear
I got it going! Checked the simple stuff and apparently had a slightly loose positive cable connection, that and what I think is maybe a ground cable clip off of the negative cable was loose. Whichever of those, it’s going now.
probably overreacted with the initial post, but I had big fear in my head from prior new battery not working
thanks for the replies!
Old Oct 2, 2025 | 05:31 AM
bclexus's Avatar
bclexus
Loose this and loose that and something else fell off - well damn, somebody did a shitty job of replacing and checking his work!
Old Oct 2, 2025 | 05:56 AM
aph7649's Avatar
aph7649
3rd Gear
no doubt! Can’t find good help any more
eggers
Hybrid Technology
Dec 17, 2022 11:20 PM
CrimsonF
RC F (2015-present)
Dec 8, 2021 10:17 PM
BearsLexus
RX - 1st Gen (1999-2003)
Oct 20, 2013 01:29 PM
clynnh1230
Jul 18, 2013 05:28 AM
grindin8o8
Jan 25, 2010 06:08 AM
