smog sensor settings
Old May 4, 2025 | 10:56 AM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
Default smog sensor settings
Just bought a 2016 GS 350 with 32k miles on it and would like to see what the smog level sensor is set at.Can not find it in the manual.
Any help will be much appreciated. Thanks.
Old May 4, 2025 | 12:56 PM
EAST's Avatar
EAST
You can see it/change it in Techstream. I'd have to see if it's also visible using a regular OBD2 dongle.
"Emission gas sensor shift"
Looks like there's another in the head unit under Settings, vehicle, vehicle customization, climate settings.
Old May 4, 2025 | 06:39 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
Thanks!
Old May 7, 2025 | 08:27 AM
CottageChz's Avatar
CottageChz
I’m curious to see if this makes a difference for you. In my first GS (2013) it seemed like my car would switch to recirc very quickly if anything smelled bad outside. In my new GS (2017) it seems to switch much later, if at all. I have the sensor set in the infotainment menus to be as sensitive as possible, and I also took it out and cleaned it.
Old May 7, 2025 | 10:00 AM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
I set mine at number 2 on the least sensitive and it switches over pretty often.
bgdman
RX - 4th Gen (2016-2022)
Jan 16, 2025 11:28 PM
autamax
Aug 4, 2023 08:30 AM
Dingus
Sep 30, 2022 01:12 PM
wtdt
Dec 21, 2010 02:38 PM
