All warning light on
Old Sep 15, 2022 | 12:40 PM
KingZKoa's Avatar
KingZKoa
2nd gear
Default All warning light on
Aloha,
So I just just bought a 2006 Gs430. Currently it is showing all the warning lights on the cluster, hard start up and if driven to long long it loses power. Anyone had this issue before??
Old Sep 15, 2022 | 04:52 PM
titangts's Avatar
titangts
Originally Posted by KingZKoa
Aloha,
it could be so many things….
disconnect the negative on your battery then after, go and hit the brake pedal (dislodges all residual energy). Wait 15 mins and reconnect the battery and see if anything changes.
if lights still on then get the codes scanned to figure out what it is.
Old Sep 16, 2022 | 10:44 AM
ibidu1's Avatar
ibidu1
Sounds like a charging issue! But whats common is when these cars sit not driven they do throw a lot of engine codes. So if the car starts and drives, and doesnt drain the battery just drive it and usually a day they magically fix themselves.
If the problem doesnt go away, then I would grab a voltmeter and run test on the battery terminals with the engine running. You want to see mid 13 volts charging steady while at idle.
janni73070
NX - 2nd Gen (2022-current)
Jul 6, 2022 08:43 AM
se_bb2
Jan 22, 2010 07:40 PM
dahozzman
Dec 21, 2003 09:37 PM
xsuperjoex
Oct 28, 2001 07:20 AM
