Headlights
On another note, I’m seeing plug and play LED replacement bulbs for the Halogen high beams. Has anyone tried these? My high beams work fine but an upgrade would be nice.
Osram -
Cool Blue Boost (CBB) 7000k, 3200lm, 1500hr
Cool Blue Intense (CBI) 6000k, 3200lm, 2000hr
Cool Blue Intense NG (CBN) 6200k, 3200lm, 2000hr
Night Breaker Laser (XNL) 4400k, 3200lm, 2000hr
Xenarc Original 4500k, 3200lm, 2000hr
Xenarc Ultralife ?k, 3200lm, ?hr
Philips - Standard 4200k, 3200lm, 1500hr
Although they all claim 3200 lumens, usually with a +/- 450 lumen variance, various you tube video comparisons show a noticeable difference with the Night Breakers seeming to output the most light, albeit not the whitest and the Cool Blue Intense NG coming in a close second. The videos I’ve watched so far haven’t used D4S, most use D2S. I’m not sure if that makes a big difference or not.
Last edited by CruzinGS; Feb 2, 2022 at 02:09 PM. Reason: Added info about DRL flicker
My car interestingly enough doesn't have any sort of DRL (I want to get this changed to fog lights if possible)
However in most cars your are correct in that the high beams are run at a lower voltage as a DRL
The easiest thing to do (and what I have seen the most on the forum) is to use LED bulbs that only work as DRL and forego having high beams
I haven't actually come across any links to bulbs that will correctly function as high-beam and DRL
I changed my parking lights out for LED bulbs recently and checked just before and it looks great!
I didn't start the car, but it appears that with my headlights on, the high-beam stays off so I get the LED effect with stock hi-beam bulb.
