Aftermarket Amplifier
Old Oct 18, 2021 | 04:04 AM
handzilla's Avatar
handzilla
Default Aftermarket Amplifier
I have been having some issues with my amplifier as of recent. After raining, there has been popping sounds coming from the speakers when the car is off. Following some research, I believe this is due to moisture accumulation near the amp and can possibly be resolved by replacing quarter vent on the passenger side.
As a proactive measure, I would like to know if there are any aftermarket amplifiers that are plug and play and could possibly even improve the sound for our cars.
Thanks!
Old Jan 4, 2023 | 12:18 PM
handzilla's Avatar
handzilla
bump, can anyone recommend a replacement for the OEM amplifier that is plug and play?
Old Jan 4, 2023 | 12:23 PM
Such a thing doesn't exist, unless used OEM.
Old Jan 4, 2023 | 12:47 PM
handzilla's Avatar
handzilla
Would I be able to swap it for a used Mark Levinson?
Old Jan 4, 2023 | 12:55 PM
ibidu1's Avatar
ibidu1
My car has the same issue, how funny it happened today. Ive tried unpluging the electrical connections, and cleaned them all out with electrical spray. Still no luck! For some reason I dont think the issue is the amplifier, because even the sound when you switch ac fan the little beep is not there.
But its definitely rain moisture thats causing it, but where, thats still a mystery.
Old Jan 4, 2023 | 01:19 PM
Sure, they are generally not hard to find on Ebay. What year is your car?
.....I see in you profile 1999 is that correct?
Old Jan 4, 2023 | 06:12 PM
handzilla's Avatar
handzilla
Wow I still haven't updated my profile yet. 2009 GS 350. Would the ML amp cause any issues with the non-ML speakers? Is the sound quality that much better too?
Old Jan 5, 2023 | 04:26 AM
ibidu1's Avatar
ibidu1
The ML amp will not work on a non-ML car, totally different system
Old Jan 5, 2023 | 08:50 AM
handzilla's Avatar
handzilla
Thanks for the info.
Moisture is known to accumulate in the area that houses the amplifier, so be sure to check inside the trunk on the passenger side. There is a vent there that helps humidity escape to the outside, so that may need to be replaced. Part No.: 62930-12160. I did this in 10/21 and all went back to normal until yesterday when I picked my car up from Costco for a tire rotation and balance. Now I have no sound, so I went ahead and ordered a used amplifier off of ebay.
Old Jan 5, 2023 | 12:58 PM
ibidu1's Avatar
ibidu1
I actually checked the amplifier when it was not working for moisture. It was dry! The area was dry! I thought about removing the amplifier and opening it and cleaning out the terminals inside of it, and making sure the amp get sealed. Maybe add a little silicone on the corners and openings.
Because if the amp works when the rain stops and everything drys, then the amp is still good. It might just have a sealing issue, thats allowing moisture to enter. If you buy a used amp it may have the same issues.
Old Jan 5, 2023 | 04:38 PM
joesphan's Avatar
joesphan
5th Gear
I have one of these aliexpress jawns. costs $300-500. I quite like it, except for the fact that the temperature's always stuck at "-1", despite the temperature working. All plug and play aside from the backup camera, which you have to tap into a rca video signal near the passenger door.
Old Jan 6, 2023 | 04:44 AM
handzilla's Avatar
handzilla
Still possible some moisture got in there, I would remove it, take a closer look, and maybe clean. Yes the amplifier still may be good, but from what I have read, they usually go out soon after they start having this issue.
Old Jan 21, 2023 | 02:44 AM
handzilla's Avatar
handzilla
The used amplifier I purchased from eBay resolved the issue. Now I just need to ensure that moisture stays out of that area.
djc102987
RX - 4th Gen (2016-2022)
12
May 4, 2023 02:25 PM
DMPesso
Aug 11, 2021 09:53 AM
Donniekays
Mar 4, 2018 07:48 PM
Cybernetic
Apr 16, 2012 09:15 PM
juan01
Jan 13, 2005 08:08 AM
