Mid pipe
Old May 4, 2020 | 11:31 AM
energie8's Avatar
energie8
Default Mid pipe
Any of you guys know if our oem mid pipe is stainless steel?
Old May 4, 2020 | 11:37 AM
ibidu1's Avatar
ibidu1
More likely mild steel thats galvanized, because awd mid pipes are known to rust out.
Old May 4, 2020 | 09:01 PM
RamAirRckt's Avatar
RamAirRckt
my 08GSh has the left mid pipe replaced already before I bought it. If it is like my 2GS4 it is the steel clamps that hold the heat shields in place that aggravates the rust holes.
I patched my 2GS4 with band clamps and it lasted 328k miles. Keep the stock pipe if you can.
Old May 6, 2020 | 07:35 AM
ServerTech's Avatar
ServerTech
Absolutely not! Its just thin mild steel and rusts out under the attached heat/noise shields here up north.
Old May 9, 2020 | 02:20 PM
energie8's Avatar
energie8
That sucks, I have some leak near the muffler also, so I was just planning to change the whole thing. Would this work if I buy a new set of OEM muffler and connect it to a stainless steel Nvidia or megan midpipe. it would be a cheaper alternative than spend 3000cad on a new oem full exhaust system. And which would be less noisy?the Nvid or Meg midpipe?
Old May 9, 2020 | 02:44 PM
ibidu1's Avatar
ibidu1
You can weld mild steel to stainless, its not ideal and wont last aslong, but its doable. Its best to use stainless welding wire, and you can use regular. Why dont you take it to a good muffler shop and have them custom make you an exhaust. Wont hurt to get a couple of price quotes and see what they can offer.
Heres a rear muffler off ebay for a rwd https://www.ebay.com/itm/Exhaust-Muf...cAAOSwIYdeYO9W
Old May 17, 2020 | 03:42 AM
designo's Avatar
designo
It's galvanized steel
accordvtec
Performance
23
Sep 18, 2020 12:14 AM
elidari
Jun 20, 2017 08:10 AM
ksan
Nov 12, 2016 09:24 AM
2012IS250
Performance
Aug 21, 2014 12:49 PM
ethotie525
Performance
May 13, 2014 03:12 PM
