Low speed wobble
Old Jul 8, 2019 | 05:48 AM
silverlake's Avatar
silverlake
Default Low speed wobble
So I’m lowered on tanabe springs no issues until I put on Megan 30 mm rca spacers now slight shake st low speed and feels like my steering is all over the road at highway speeds do you think it’s because the rca are more then the drop from springs ? I have all new kyb struts
Old Jul 8, 2019 | 08:34 AM
tghw's Avatar
tghw
If it was fine before you installed them, I'd say that's a pretty good indication as to what's causing the problem.
Old Jul 8, 2019 | 08:55 AM
silverlake's Avatar
silverlake
Sucks cause I like the look !!
Old Jul 8, 2019 | 09:31 AM
ibidu1's Avatar
ibidu1
When you installed the RCA did you do an alignment after?
Old Jul 8, 2019 | 10:40 AM
silverlake's Avatar
silverlake
I didnt but I had one done right after the springs were installed I notice my alignment is off now because of the blocks
Old Jul 8, 2019 | 11:50 AM
ibidu1's Avatar
ibidu1
Align it and see how it rides, because when you installed the rca your alignments all out of whack.
Old Jul 8, 2019 | 03:09 PM
silverlake's Avatar
silverlake
Yeah I will I’m just not sure it will help the vibration from the axels because when I let of the gas it rolls fine only when under load is when it does it
Old Jul 8, 2019 | 03:23 PM
mspearl95's Avatar
mspearl95
Your wheels could be pointed different directions, when they are being pushed forward by the engine, causes extra resistance and vibration in the system.
Old Jul 8, 2019 | 06:27 PM
silverlake's Avatar
silverlake
Well if I turn my wheels and take a pic of the axles will that give you an idea of the angle ?
Old Jul 8, 2019 | 09:38 PM
mspearl95's Avatar
mspearl95
Thats not really something you could tell from looking at it, especially by photo. Gotta put it on the alignment rack.
Old Jul 9, 2019 | 08:39 AM
silverlake's Avatar
silverlake
I figured I’d add pics anyways to see if you notice anything with axels lca is parallel with road
Old Jul 10, 2019 | 09:43 AM
silverlake's Avatar
silverlake
Something else I’ve noticed is when I first start car and drive it doesn’t do it until a few mins later ?? Weird
Old Jul 10, 2019 | 09:51 AM
ibidu1's Avatar
ibidu1
Ive your still driving it without an alignment, you will kill your front tires very quickly.
Old Jul 10, 2019 | 10:13 AM
silverlake's Avatar
silverlake
I am still without an alignment since the rca install so what I’m going to do is remove them first to see if it goes away because I didn’t have this happen before them and if all is well I’ll re align
Old Jul 10, 2019 | 10:32 AM
ibidu1's Avatar
ibidu1
Try aligning it before you remove them, then if you still get whobble maybe then you can take the spacers to a machine shop and have him shave them down a bit, maybe knock off 10mm off the spacers. Then see if it helps! RCA will throw off your alignment from stock, you will get a whobble because the geometry is off and it needs to be corrected with an alignment.
Also some big name alignment shops you can purchase a 1 year plan, instead of paying for each alignment.
