Shocks and struts replacement?
Old Dec 7, 2018 | 09:53 AM
Morfeeis's Avatar
Morfeeis
Default Shocks and struts replacement?
Keep hearing this clunking in the rear end when going over bumps, was told by the dealer that I needed rear suspension replaced. Saw this and figured I would do it myself, what about Springs, don't I need Springs? If so anyone know what the factory Springs are?
also how difficult of a job is this? I've replaced water pumps alternators brakes and a few other nick-nacks, but nothing major.
https://www.amazon.com/KYB-FRONT-REAR-shocks-struts/dp/B002T08SWQ
Old Dec 7, 2018 | 10:10 AM
ibidu1's Avatar
ibidu1
Its fine to reuse the old springs! You will need to rent a spring compressor from your local parts store. I would also replace and check the suspension bushings, grab a pry bar and press against the bushings. I would also replace the front lower control arm big bushing, its cheap and will help tighten the steering.
Old Dec 7, 2018 | 10:32 AM
Morfeeis's Avatar
Morfeeis
thanks for the info! So the control arm bushing and the suspension bushing are worth doing while I'm down there huh thanks
Old Dec 7, 2018 | 07:54 PM
ibidu1's Avatar
ibidu1
Theres only 1 on each side that does fail but it, usually it wont appear it has failed. https://www.ebay.com/itm/LEXUS-ORIGI...kAAOSwEH9ZaAtx
I would test the rest of the bushings with a pry bar and see if theres any cracks in the rubber.
cleethree
Oct 2, 2016 08:06 PM
Studiogeek
Feb 24, 2013 07:03 PM
djrazr
Apr 1, 2010 10:42 AM
cnstarz
Feb 24, 2008 06:52 AM
Ryan
Aug 23, 2002 02:51 AM
