P0204 injector open closed circuit
Old Nov 29, 2018 | 10:48 AM
ibidu1's Avatar
ibidu1
Originally Posted by Will305
The diagram is not much help can you guys help me if there's a more accurate one
Try this
http://www.bbbind.com/free-tsb/
Old Dec 3, 2018 | 08:43 AM
Will305's Avatar
Will305
can anyone tell me what's the difference between direct and indirect injector and where are the direct injectors located for 2010 gs 350 3.5
Old Dec 3, 2018 | 08:54 AM
potatomon's Avatar
potatomon
Direct injectors spray into the combustion chamber and sit in the heads. Port injector s spray into the manifold right before the intake valves
Old Dec 3, 2018 | 09:38 AM
Will305's Avatar
Will305
so the direct injectors sit on top of the heads correct how many direct injectors are there
Old Mar 6, 2022 | 12:44 PM
verko's Avatar
verko
2nd gear
I was driving to work I noticed the vehicle started miss firing to vehicle to the shop shop worker advised me that I had an open closed circuit on injector number 4 he checked the wiring found nothing replaced the ecm and the injector driver and the coil pack on that cylinder still nothing can someone help me the vehicle is a gs 350 2010 AWD with about 150k on the dash vehicle was well maintained
Hi, I have a Lexus Ls 460 with the exact same problem, I get the same error. I've swapped the injectors, checked wiring, swapped spark plugs and ignition coils, but the injector 4 error remains... I've done everything possible, what's the outcome of your lexus? thanks anyway!
Old May 22, 2022 | 06:50 AM
Marion777's Avatar
Marion777
3rd Gear
Default Lexus LS 460 VSC and fuel injector open circuit
Hi
Did you ever fixed your problem on the fuel injector open circuit? I jus got the same issue, swapped coils, injectors, checked the harness. Motor runs rough , check engine is one with warning to check my VSC system. Codes read P0204 and P0304.
there was no warning and it just came on one morning. I know I’m going to get reamed at the Lexus dealership.
Old May 22, 2022 | 06:59 AM
Marion777's Avatar
Marion777
3rd Gear
Hi
Old May 22, 2022 | 07:26 AM
ibidu1's Avatar
ibidu1
Originally Posted by Marion777
Hi
The coils and the injectors did you buy them oem or chinese aftermarket? If you bought aftermarket, honestly I would reinstall the old stuff. Take it to a good mechanic, no need to take it to a dealer, a good mechanic (who specializes in toyota/lexus) with a scan tool should be able to solve it.
Old May 22, 2022 | 09:31 AM
verko's Avatar
verko
2nd gear
Hi
hello, yes i managed to solve the problem. I thought there were 8 fuel injectors (low pressure) present but there are 16... the first 8 that are visibly mounted are cold start injectors and the other 8 (high pressure) are mounted under the inlet collector. I saw rats biting the wiring of the fourth fuel injector below the intake collector.
Old May 23, 2022 | 05:16 AM
Marion777's Avatar
Marion777
3rd Gear
I only see one row of fuel injectors on each side of the intake. Where are the other 8 located? Are they under the intake? Does anyone has any diagrams on this?
Tmurder
Dec 3, 2015 07:49 PM
RX300tina
RX - 1st Gen (1999-2003)
Jun 18, 2014 12:35 AM
badabing1
Apr 24, 2012 08:15 PM
WainiacS
Nov 28, 2011 07:04 AM
phil128605
Jun 22, 2010 11:30 AM
