2006 GS300 - changed alternator
Old Sep 8, 2018 | 06:03 AM
Charis's Avatar
Charis
Default 2006 GS300 - changed alternator
alternator was barely charging, so changed it out. Now power steering and a/c not working. what should i check for ?
Old Sep 8, 2018 | 02:15 PM
ibidu1's Avatar
ibidu1
Check the battery voltage, make sure the terminals are clean and solid. Especially the nut on the terminal take it apart and clean it. If your are not getting above 13.3 volts with the car running then your issues is with the alternator or wiring.
Old Sep 8, 2018 | 02:20 PM
Htony's Avatar
Htony
If played the AM radio it will be very noisy with whining kind of noise. Also lights could flicker. It could be a battery problem (like one cell short internally).
Old Sep 8, 2018 | 05:48 PM
Charis's Avatar
Charis
Thank you -- will check that
Old Sep 8, 2018 | 05:49 PM
Charis's Avatar
Charis
Thank you - will check the battery again
tuffwesdev
Jun 23, 2017 03:21 PM
reckedhim
GX - 1st Gen (2003-2009)
12
Dec 23, 2015 07:36 AM
Vmoney
GS - 1st Gen (1993-1997)
Aug 3, 2006 10:15 AM
STRONG SC
Oct 10, 2005 12:58 PM
SC4Hundred
Feb 10, 2005 02:49 AM
