Tesla Style Headunit with OEM Camera
Subscribe
Jan 20, 2020 | 07:35 AM
  #61
Quote: Great idea! Please let me know how it works out, because i would much rather use the original brackets.
...Also, how did you come up with the measurements for the new holes?
I made the holes in the original brackets today as marked in the photo:
The second hole located in the curved area. I will make it straight by a hammer. I am thinking of taking the measurements from the center of the new coles to the center of the nearby holes for you to be able to make it.
What do you think?
Reply 0
Jan 21, 2020 | 05:20 AM
  #62
Here are the measurements :
See the holes are aligned to the body holes :
Reply 0
Jan 21, 2020 | 11:24 AM
  #63
I noticed something with the new unit. Regardless how secured I made it with the brackets, the unit is flimsy and made of plastic and thin metal. So it moves when you press the corners of the unit.
Reply 0
Jan 21, 2020 | 03:40 PM
  #64
Quote: I noticed something with the new unit. Regardless how secured I made it with the brackets, the unit is flimsy and made of plastic and thin metal. So it moves when you press the corners of the unit.
Mine's the same at the top-left. There's a gap inside the unit there. I opened it up and put a wedge in to stop it pressing in.
Reply 0
Jan 21, 2020 | 03:55 PM
  #65
Quote: Mine's the same at the top-left. There's a gap inside the unit there. I opened it up and put a wedge in to stop it pressing in.
Thanks for your response. That's what I was thinking of doing too😊.
Reply 0
Jan 21, 2020 | 04:02 PM
  #66
Quote: Thanks for your response. That's what I was thinking of doing too😊.
Mine randomly mutes. I'm concerned that my mod causes this since it's right by the mute key. I'm gonna remove it for a bit and see if it stops.
Reply 0
Jan 21, 2020 | 04:08 PM
  #67
Quote: Mine randomly mutes. I'm concerned that my mod causes this since it's right by the mute key. I'm gonna remove it for a bit and see if it stops.
I saw one video in YouTube about one guy was facing random mute.... Was it you?
Then I read somewhere that it happened to more than one person. So, I don't think that was the reason.
Reply 0
Jan 21, 2020 | 04:09 PM
  #68
Reply 0
Explore
Jan 22, 2020 | 04:14 AM
  #69
Quote: https://youtu.be/zG5rvJLHX8M
That's not me so I'm glad I'm not the only one.
Reply 0
Jan 22, 2020 | 12:38 PM
  #70
I secured the unit with some brackets I fabricated. It is not moving now in any corner, even if I press so hard.
One peace in the top:
And two "L" shape in the sides :
Reply 0
Jan 22, 2020 | 01:09 PM
  #71
Also the top-right corner of mine pops out (above the surrounding trim) sometimes.
Reply 0
Jan 22, 2020 | 01:14 PM
  #72
Quote: Also the top-right corner of mine pops out (above the surrounding trim) sometimes.
Mine now no pop out, no pop in. Solid, I am happy now😊
Reply 0
Feb 20, 2020 | 01:41 AM
  #73
I have one question for the ones that have ML system. I have a 06 GS and i did the camera mod and works perfectly (thank you very much for the post).
How is you sound quality working, i think i´ve lost some sound quality (mainly i guess the bass is too present in the front speaker and distords in some songs). Wich setup are you using for the android EQ and for console settings? I´ve tested with CANBUS setup (GS LO, GS HI) and i would say with LO sounds better. Also, i´ve noticed that the ASL function is on (YES) on console module at low speed but at higher speeds it turns off (NO)
Reply 0
Apr 14, 2020 | 11:49 PM
  #74
lexis is 350 2007 android tesla unit
Hey does anyone know how to get the air conditioner to connect to the Tesla screen? I plugged in the main stereo harness given but still no ac working. also having trouble with my factor back up camera and my hazards. if there is any video or instructions on the installation. of this 10.4 headhunt pleas let me know.
Reply 0
Apr 18, 2020 | 11:14 PM
  #75
I could not find the Television camera controller.
I couldn’t find the television controller. Is there any other way I can locate the wires for the RCA jack?
Quote: Hi Everyone,
I will explain how I managed to connect my Tesla Style headunit to the OEM camera in my GS 2006.
My car comes with Mark Levinson System and Navigation. I don't think it will make a defferance, but FYI.
1. Remove the glove compartment to reach the wires coming from the camera to the (Television Camera Controller).
Behind the glove compartment
2. You need one meter long RCA cable and cut the head from one side. Locate pin 39 [CV-] (gray wire) and pin 40 [CV+] (red wire) in the K64 plug. Connect the center wire of the RCA cable to pin 40 and the shield to pin 39. After you finish run the other end of the RCA cable to the headunit and connect it. Make sure if you unplug K64 to plug it back because the OEM camera is taking 6.4v power from pin 20[CB+] and pin 19 [CGND] of K 64.
2006 GS OEM camera connection
K 64
3. Now go behind the Headunit and locate pin 13 [REV] (red wire) in the K 46 plug and connect it to the reverse wire from the Headunit. I used an extention wire to reach it easly.
Reverse Signal comming to the OEM unit
K 46
Reverse and Illumination Wires
Bonus (not related to camera):
Connect pin 12 (green) of K 46 plug to the illumination wire of the Headunit to dim the screen when you turn on the headlight.
Reply 0
