Camshaft sensor
Old Mar 12, 2018 | 08:54 PM
Malmanzar's Avatar
Malmanzar
Default Camshaft sensor
hey guys if anybody can provide information on a 2006 Lexus GS 300 camshaft location, please
Old Mar 13, 2018 | 06:29 PM
nobelnabil's Avatar
nobelnabil
hi, i think (not 100% sure), that there is no camshaft sensor in Lexus, they use what is called Variable Valve timing sensor (VVT Sensor) instead. see attached for the location
Old Mar 13, 2018 | 06:41 PM
Malmanzar's Avatar
Malmanzar
Default Can shaft position sensor driver side
The corrrect information is camshaft position sensor drive side
Old Mar 14, 2018 | 08:11 AM
SILENTM's Avatar
SILENTM
There is 4 cam shaft sensors 1 for intake 1 for exhaust on each bank they are located on top of the valve covers. intake cam sensor is towards the front of the engine and the exhaust is between two ignition coils. Intake is normally read as camshaft "A" and exhaust as" B" and which ever bank has the fault. Normally these faults can come on due to low oil. Crank shaft position sensor is behind the alternator. If trouble shooting you can switch any of these sensors as they are the same and clear codes to see if the fault stays with the sensor you suspect is bad. Hope this helps
pyr8
May 28, 2018 10:55 PM
djrazr
May 8, 2010 03:02 PM
MR2-Mike
Sep 22, 2008 07:53 AM
blk99rx300
RX - 1st Gen (1999-2003)
Jul 16, 2006 07:23 AM
