Replaced Struts, Dash went haywire...
Old Feb 18, 2018 | 09:17 AM
user 528962307's Avatar
user 528962307
Exclamation Replaced Struts, Dash went haywire...
ten characters
Old Feb 18, 2018 | 09:26 AM
tghw's Avatar
tghw
How old is your battery?
Old Feb 18, 2018 | 09:44 AM
user 528962307
ten characters
Old Feb 18, 2018 | 10:21 AM
gs350fan's Avatar
gs350fan
Originally Posted by Bdd12382
. I have check vsc and check abs blinking along with the lights you see. .
You damaged an ABS sensor or wire.
Old Feb 18, 2018 | 10:34 AM
Gs3500's Avatar
Gs3500
Pull the code... Any decent obdii reader should help pinpoint the problem circuit.
Old Feb 18, 2018 | 10:35 AM
user 528962307
ten characters
Old Feb 18, 2018 | 12:39 PM
gs350fan's Avatar
gs350fan
May need TIS for ABS, it is real cheap on ebay if you just want to read codes.
Old Feb 18, 2018 | 01:02 PM
user 528962307
ten characters
Old Feb 20, 2018 | 09:46 AM
aristo1987's Avatar
aristo1987
Well I dont have a reader until I go back to get the tire sensor installed. Wanted to know what you guys think.
hard to say. Get a ob2 reader.
Old Feb 20, 2018 | 10:48 AM
DEONDRE's Avatar
DEONDRE
Try unplugging your battery for 2 minutes and plugging it back in and see if that solves the issue.
Always try to start with the cheapest method first before spending $$$ on something you may not need.
Old Feb 20, 2018 | 01:36 PM
XxGoKoUxX's Avatar
XxGoKoUxX
I see afs off too.... installer might have also put leveling arm back wrong.
gs350 might be right... broken abs sensor (install error?) Or they just didnt connect it when reassembling.
Old Feb 20, 2018 | 03:47 PM
user 528962307
ten characters
Old Feb 21, 2018 | 07:42 AM
gr8fulRed's Avatar
gr8fulRed
So here is a snapshot of my dash. Installed new tires, got the tire pressure sensors lights. Found out one of my sensors is bad after installing the tires. Will replace that. But after my front struts got replaced a week later, my dash went haywire a couple days later as you can see. I have check vsc and check abs blinking along with the lights you see. Now the car drives like a dream after everything was installed but now this problem. Anyone had this problem after replacing struts? Any suggestions and solutions to this problem are greatly appreciated, thanks.
out of curiosity....what symptoms were present that suggested you needed new struts? How much did they cost you? How many miles were on the original struts?
Thanks!
Old Feb 23, 2018 | 02:00 PM
user 528962307
ten characters
Old Feb 24, 2018 | 09:37 AM
gr8fulRed's Avatar
gr8fulRed
Bumpy ride, lots of rattling and clunking. When my mechanic put it on the lift, struts were leaking oil, and blown out. I had to do the same on my 1999 GS300 around the same mileage 130k. Struts were like $80 a piece with mounts $45-50 a piece.
thanks for the info! I'm at 140k, so I need to keep an eye out for that.
