Harsh 2-1 Downshift 2006 Lexus GS300 P0756 Code
I am experiencing a harsh 2nd to 1st gear downshift. My code reader shows a P0756 shift solenoid issue. I took it the stealer and of course they said I needed a new transmission for $5000. I would like to find out if there is a lower cost option like just replacing the shift solenoid. Am I wasting my time going from dealer to dealer? Would an independent transmission shop be able to replace just the shift solenoid? How much should I expect to pay for a shift solenoid replacement? If it's worse, is it any less expensive going to a Toyota dealer for the transmission vs. Lexus? I appreciate any assistance. I live in the San Francisco, Eastbay Area.
Your dealership experience sounds about right: Most like to remove and replace the entire piece, as it can be easier/more cost-effective for them (and more expensive for you). I've seen this issue mentioned elsewhere on the forums, and someone even created a DIY replacement guide for the solenoid (albeit for a SC400) --
https://www.clublexus.com/forums/per...placement.html
The solenoid itself is replaceable. I'm guessing a local transmission shop should be able to do it for around $500 or so (I don't have an exact estimate, as I haven't encountered this issue personally. Sorry!) A quote from an independent repair shop wouldn't hurt, either. As far as Toyota vs. Lexus is concerned, the only savings I've seen are on labor costs. Lexus dealers seem to charge $120-160/hour for labor vs. a $90-100/hour charge from Toyota. Because of that, I wouldn't waste too much time going from dealer to dealer as the quotes won't be dramatically different.
Let us know what you find!
Thanks for the information. I surmised that the ECM would be the least costly option if it was repaired, $100 plus shipping. I took to a local transmission shop, Schucks Transmission, just to confirm my previous finding. After road testing, they also told me that most likely that it is the ECM that is causing the harsh 2-1 downshift and quoted $1500 for the part plus labor. I purchased a repair option for the ECM through SINA on EBAY. Though, I am not sure if it would need to be reprogrammed after re-installation.
Not a problem. When they diagnosed the ECM, did they mention anything about the TCM? My father used to have a 2003 RAV4 that had a transmission issue (harsh shifting, hunting for gears, low idle, etc.) and he was able to get the TCM reprogrammed thru a third-party for $300 or so. Once re-installed, the problem vanished completely.
SIA Electronics has my ECM and they did mention that the ECM includes the TCM which they stated they would replace. Waiting to test the results of the ECM rebuild.
SAVED THOUSANDS OF DOLLARS! Stealer told me I need a new transmission. I had my ECU sent to SIA Electronics and had them replace the transmission control module. Car runs fine now without the harsh shifting. Could not be happier with the results.
Was the ECM/TCM module easily removed for shipping to SIA? Glad to hear of your fix, would love to try it myself.
How difficult was it to remove the ECU? Do you have instructions or was it removed by the transmission shop?
Not difficult at all. But it's been awhile and I no longer own that car. It is the black plastic oblong box, standing upright on the driver's side near the headlight. I believe you just have to remove a hose, and unbolt it and remove the plug clip. I'm a bonehead, so if I can do it, anyone can.
