Clunking from front brakes
Old Sep 22, 2017 | 05:34 AM
carnut1980's Avatar
carnut1980
Default Clunking from front brakes
Hi all, my front brakes make an annoying 'clunk' when braking, usually when going slowly then braking fairly hard, but most prominent when braking, then reversing, then braking, then going forward again, then braking, etc
It doesn't always do it with general driving. The front discs and pads are new, but the clunking was occuring before this.
327k miles on the clock, drives perfectly!
Please see attached link for the noise its making!
Any ideas?
http://www.lexusownersclub.co.uk/for...omment-1014263
Old Sep 22, 2017 | 07:15 AM
XJSFan's Avatar
XJSFan
Most likely the caliper...
Old Sep 22, 2017 | 10:31 AM
primavera's Avatar
primavera
Clean and lubricate caliper pins, I've used Sil-Glyde in the past with great results.
Old Sep 24, 2017 | 06:57 AM
xkazik's Avatar
xkazik
I have the same problem mine is a 09 with 26k on it. I am reading that previous Gs have the same problem someone fixed it by installing brake pad shims but i haven't found any for my model . Its from brake bad movement i am guessing
Old Sep 26, 2017 | 10:41 AM
saynthng's Avatar
saynthng
5th Gear
Same problem on my 06 GS430, probably brake pad movement; annoying but not harmful it seems.
shivam
May 23, 2013 04:39 AM
Bushwack
Sep 2, 2009 07:38 AM
Farino81
Jun 26, 2009 06:13 PM
gsowner88
GS - 1st Gen (1993-1997)
Aug 29, 2007 10:44 AM
Jimmer350
Suspension and Brakes
25
Jun 8, 2007 07:38 AM
