Q: Lean rich loop after catalytic delete
Old Jul 31, 2017 | 11:01 PM
pokemonz's Avatar
pokemonz
Default Q: Lean rich loop after catalytic delete
Hi,
I have GS430, year 2006.
Removed both front catalytic converters, because i was getting code P0420. Now i sometimes get P0136 code. It means Bank 1 Sensor 2 error.
After catalytic converters were removed, i used spacers on O2 sensors, that go after converters.
Now my car goes into some loop when trying to calibrate fuel/air ratio. On diagnostics program it shows that fuel must be 3% richer, then 5%, 7%, 12%, 15% and drops to 0. Then it repeats.
Should i replace O2 sensor on Bank 1 sensor 2? Maybe spacers should be changed to other brand? Any thoughts? Thanks.
Old Aug 1, 2017 | 02:04 AM
ibidu1's Avatar
ibidu1
Before buying and spending money on a new sensor that youre unsure about. Why not place the bank 1 into bank 2 swap them around and if you get an error after youve cleared the codes on bank 2 then replace the sensor.
Old Aug 2, 2017 | 08:22 AM
SILENTM's Avatar
SILENTM
Do you have right angle spacers/ adapters with restriction hole insde. Theres also and capacitor hack been done somewhere to trick the ecu. it spliced into the post o2s
Old Sep 5, 2017 | 09:55 PM
pokemonz's Avatar
pokemonz
Thank you. Right angle spacers did the job. No errors now.
kambam3627
May 26, 2019 10:53 AM
Nixcision
Jan 16, 2017 05:56 PM
bayer
Nov 14, 2016 02:10 PM
Bluv
Nov 9, 2015 01:28 PM
12340987
Jun 2, 2009 07:26 PM
