2008 GS460 Wheel Bearing
Hello,
The wheel bearing (left side) on my 08 GS460 is failing and I need to replace it. The dealer wants $280 each.....I've been looking around and rockauto.com has several aftermarkets options ranging in prices from $48-$250. They have Moog and Timken, which are brands I recognize from owning my 2nd GS. Other than these two brands, not sure if anyone has other suggestions. I would like to get some input before making my purchase. The link to rockauto is shown below. I'm leaning towards getting the Timken set. Thanks.
http://www.rockauto.com/en/catalog/l...+assembly,1636
Did you install the new assembly yet? What did you got with and how much? I was reading that the oem hub assembly comes with the abs sensor hence the price?
Not yet as I will be replacing the two front shocks at the same time. If you click on the link I provided above, you will notice that the Timken unit also comes with the abs sensor. Below is one of the features as listed on the rockauto link. I will be going with the Timken unit. I will post an update in the coming weeks.
" Fully serviceable wheel speed sensor (where applicable) is internally mounted and protected from road hazards, debris and potential damage. "
lexusisgs
Oct 28, 2023 08:50 PM
Gville350
May 28, 2019 11:14 AM
