Should I replace the Wheel bearing?
Old Apr 17, 2010 | 11:18 AM
Sup2jzgte's Avatar
Sup2jzgte
Default Should I replace the Wheel bearing?
Does this sound like my wheel bearing is starting to go south?
Old Apr 18, 2010 | 10:25 PM
Sup2jzgte's Avatar
Sup2jzgte
I know some people on here have replaced their wheel bearings without bringing it to a shop.
With this press work to press the old bearing out and the new one in?
http://www.harborfreight.com/cpi/cta...temnumber=1666
I have a $120 gift card to harbor freight and if this will work for what I need it to I will pick it up.
Old Apr 22, 2010 | 10:49 PM
pasionm's Avatar
pasionm
You probably have a bad wheel bearing. Best way to find out is install the rim back on and check for play by grabbing at 12 o clock and 6 o clock and just rock back and forth. If you feel looseness then its bad. Also just by driving it should have a loud whirring noise that goes away if you take a left or right corner at higher speeds. All it is doing is placing a load on the bearing which quiets it down.
Old Apr 23, 2010 | 08:30 PM
Sup2jzgte's Avatar
Sup2jzgte
Yeah I did the 12 and 6 and there is no movement, BUT 3 and 9 was very loose and moved my steering wheel........so its time for LCA's
Old Apr 23, 2010 | 10:42 PM
masagsxr's Avatar
masagsxr
I don't think you can press the bearing out from the hub with that. It would be good to press it in but not out. There is a special to separate it similar to this (if the link works).
http://forums.vwvortex.com/zerothread?id=1722551
edinlexv8
Apr 8, 2019 03:10 AM
Hayk
Jun 14, 2018 09:05 PM
DJohnson62
Feb 11, 2014 02:29 PM
amerquresh
Feb 10, 2011 08:27 AM
MicaISF
IS F (2008-2014)
Jan 5, 2010 02:29 PM
