Repair or Replace
Old Nov 12, 2016 | 06:11 AM
Creole222's Avatar
Creole222
Default Repair or Replace
My 2007 GS 350 has 213,000+ miles and is in need of a catalyst converter, exhaust manifold and is burning oil. Should I repair it or replace it?
Old Nov 12, 2016 | 08:33 AM
speedkar9's Avatar
speedkar9
Get a few quotes from exhaust shops around your area. They can probably cut and weld the bad sections of the pipe.
If the work is say, less than $1000, that's not much to spend on an otherwise dependable luxury car.
Burning oil is a common issue as these engines get old. Maybe you can try decarbing the engine to see if it helps.
Old Nov 12, 2016 | 01:37 PM
ibidu1's Avatar
ibidu1
Sea Biscuit, keep going!!!!
Old Nov 12, 2016 | 01:49 PM
ServerTech's Avatar
ServerTech
In order to decide what to do with the car please tell us:
Which cat converter is bad? Front left, front right or rear cats? And how much oil does it burn, how many miles before you have to add a quart of oil?
Thanks
satiger
12
May 28, 2018 12:12 PM
Wubbman
Dec 2, 2014 04:09 PM
kit cat
Apr 11, 2009 09:17 AM
johnis350
Dec 31, 2007 10:16 AM
patlexus
Jan 12, 2006 07:30 AM
