Transmission issue; Possibly?
Old 03-30-16, 08:16 AM
ksan
ksan's Avatar
Default Transmission issue; Possibly?
Hi All,
My 07 GS 350 AWD is running fine but i just recently felt this issue the other day. My car has 190,xxx miles ( i know its alot, due to commuting back and forth for work) I keep up with the maintenance such as 3k oil changes, changed air filter every 12k, changed spark plugs 20k ago, and is still running strong. BUT i haven't done anything with my transmission as of yet E.G transmission flush and fill.. All gears go in smooth, gears shift good, but I'm not sure when the first owner did a tranny flush or if ever did.
Dilemma:
I was on the high way coming off a on ramp and wanting to merge into the lane and I punched on the gas and it didn't go no where; as in it didn't down shift and go. Good way to explain it, is it felt like fuel cut in a boosted car . I then just half throttled it and it went fine. I was so boggled, so i tried to punched down on the gas again on the highway and it went fine.
Has this ever happen to any of you? I was planning on bringing it to Lexus to do the flush and fill before, but now i think its time.. Do y'all think this is a transmission issue? Any input will be very helpful or any solution to this. Thanks!
Old 03-30-16, 06:40 PM
YxUxMADDDD
YxUxMADDDD's Avatar
Similar feel. Doing my tranny flush and fill as well as differential soon. Let you know if that helps.
Old 03-30-16, 08:48 PM
Gs3500
Gs3500's Avatar
Could be bad batch of gas? How often has it happened since then?
Old 03-31-16, 05:21 AM
ksan
ksan's Avatar
Definitely let me know, thanks! I mine as well call for an appointment due to not knowing when it was last serviced.
Old 03-31-16, 05:22 AM
ksan
ksan's Avatar
That can also be it, but i usually get gas at the same gas station all the time. Im not sure if it happens often because i granny pedal the car most of the time.
Old 04-01-16, 11:46 AM
JLAWS
JLAWS's Avatar
I truly believe you caught the car off guard. It wasn't ready for you when you punched it. I've had the same thing happen to a couple of my cars on rare occasions.
But get the fluid level checked and do the 3qt flush and fill.
Old 04-01-16, 01:11 PM
TRD_Power
TRD_Power's Avatar
Another possibility could be the TPS was acting up. Doubtful with what you're reporting though . I personally wouldn't do the full tranny flush, just a drain and fill would be best; however, others swear by the flush. Hope you get it all figured out!
Old 04-03-16, 12:49 AM
xbladex00
xbladex00's Avatar
The car is getting old, but i do always feel like this car is a bit hesitant to change gears at times especially when you try to run yellows :P takes about 2-3 seconds before u dump it like 1/4 or 1/2 way. The only problem i have is jerkiness...
Old 04-03-16, 05:21 PM
tcr101
tcr101's Avatar
I noticed if you baby the throttle, it will take the trans a bit longer to kick down. I think i remember hearing somewhere that keeping it in ECT mode will have more aggressive downshifts and help with the take off.
As others have mentioned, do a drain and fill. I went the flush route and haven't had any issues in the past 10k (knock on wood). Before and after was a night and day difference atleast for me. Flushed the fluid ~110k.
Old 04-03-16, 10:01 PM
ta1972
ta1972's Avatar
Does the car jerks or has a downshift jerk when coming to a stop?
Old 04-04-16, 01:44 AM
LoveThatV8
LoveThatV8's Avatar
That's why 99% I drive it on sport mode, feels like a manual and have every control of it. Seldomly on Auto itself cause I know it lags/bogs so I rather not. Although to eliminate the thought of guessing whether or not the first owner did a tranny flushed, just serviced it for trans flush 10k miles back. Prior before that it felt a lil funky as far as itself switching gears like punching it to pass or beating a yellow light.
14RX350
RX - 3rd Gen (2010-2015)
15
08-04-18 07:05 AM
ohiois350
11-07-17 01:24 PM
TBrathwait
08-31-17 07:19 AM
haromania
12-23-15 11:03 AM
JohnGS4
Performance
02-07-06 08:41 PM
Quick Reply: Transmission issue; Possibly?
