Tire wear - no solution
Old Feb 11, 2015 | 01:37 PM
energie8's Avatar
energie8
Default Tire wear - no solution
I just got spanking new tires, did alignment at Lexus and used for 1 summer and 4 tires are wearing on the inner side(most damaged are front tires). Everything is oem, no mods, not lowered etc...all stock! except my tires/rims, I have 18" with 245/40/18 with aftermarket rims and I have hub rings with it.
Anyway, after extensive research multiple trips to various mechanics, most said it was struts so I'm going to give it a shot and replace them. I'm at 250,000KM + anyway so I could just a change. So what do you guys think the culprit is? I was thinking of even changing rims because I thought it was bent or something but it seems fine. I just wanted to try and change the cheaper parts first...
PS. Has anyone ordered from Lexus Direct Parts.ca before? It's the cheapest I can find so far but their site looks fishy...beats dealer price anyway.
Old Feb 11, 2015 | 01:42 PM
burny's Avatar
burny
Struts made my wifes GS350 tires wear just like you said. Replaced them and these Nitto 555's have no wear at all like that with over 10k on them
Old Feb 11, 2015 | 01:43 PM
burny's Avatar
burny
I bought KYB struts from Rockauto and the OEM were identical to them
Old Feb 11, 2015 | 07:44 PM
GS350Lexus's Avatar
GS350Lexus
I would use oemlexusparts.com or sewells. Might want to order bump stops also with that. kyb has a Q and A for the shocks causing tire wear http://www.kyb.com/knowledge-center/...wear-unevenly/ some good info on tire wear http://www.monroe.com/en-US/support/Symptoms/Tire-Wear
Old Feb 12, 2015 | 12:40 AM
arnieosp's Avatar
arnieosp
Nitto builds tires for cars with negative camber, the model NeoGen, with re-enforced inside edge. I have a set on my car, they are the best tires I've ever had. I have around 30K miles on them and they still have about 30% more of tread left.
Old Feb 12, 2015 | 12:51 PM
PhantomV's Avatar
PhantomV
your front Lower control arm (LCA) #2 bushing could be bad and need to be replaced. I had mine replaces with FIGS RAcing poly Bushing. Car is fine so far with them with no wear. look into that also since you are stock. this problem usually arrives after about 50k miles or so.
Old Feb 12, 2015 | 01:22 PM
TRD_Power's Avatar
TRD_Power
According to the alignment shop I go to, the 3GS' are a nightmare to correct properly. Not sure how true this is, but apparently certain wheels (forget if he said front or back) aren't able to be adjusted much?
Old Feb 13, 2015 | 09:17 AM
uberEJ's Avatar
uberEJ
AWD or RWD. make sure you tell your alignment guy because they have different settings for factory alignment. i had a vibration problem from where they were aligning my car to RWD specs when i was AWD. sometimes people that do the alignment dont care they just enter the car model and make and click whatever is showing on their menu before they do the alignment.
but yes shocks can also be a culprit. and what phantom says the LCA bushings can get worn pretty easily since they are rubber. i made the investment to go with FIGS LCA. made a world of a difference and will never regret it
the 3gs is not a nightmare to align lol. ride height first, camber (if you got it), then toe... simple. =) only took ath the most 45 min to do mine. i believe the rear camber cannot be adjust with stock parts and the rear toe cannot be adjust that much.
LexuZ786
Jun 1, 2013 09:20 AM
mrblister
Aug 11, 2010 05:59 PM
250BigAl
Jul 8, 2009 11:14 AM
GS2006
Mar 24, 2009 08:31 AM
iKenn
Feb 8, 2009 05:45 AM
