Car wont start
Old Jan 23, 2015 | 07:01 AM
bluespidey's Avatar
bluespidey
Default Car wont start
Hey guys wanna pick your brains. I have an 06 gs430 and before the winter the car ran great, Started up just fine. I then put the car on jackstands to have my wheels powdercoated. I disconnected the terminals and had a trickle charger on the battery. Went to hook up everything up 2 weeks later and the car doesnt crank.
-All the lights turn on
-Checked the fuses and they are all good
-Battery is good
-did the lock/unlock trick
any help would be great guys!
Old Jan 23, 2015 | 09:22 AM
gr8fulRed's Avatar
gr8fulRed
-Battery is good
since you disconnected your battery, it's very likely that your issue is simply the "anti-theft" system keeping the car from starting. Can I assume that the starter doesn't even crank when you push the button?? You may either have to look in your manual OR call the Lexus service dept to find the sequence...but when my battery was replaced, the selling dealer had to "re-set" the system using the key fob and a series of actions (much like resetting your maintenance lights). Once they did that....thing fired right up like normal. That would be the FIRST thing I'd check.
Old Jan 25, 2015 | 05:47 PM
DrexLex's Avatar
DrexLex
The display does not tell you anything? Like key not detected, or some such message? No sound of relay clicks under the bonnet?
My 2006 GS430 refused to start a few weeks ago after I had driven away from the house and parked a short time with the radio on. Lights/radio still worked. It was the battery. Dropped in a new one, all good again. That was the original -- 9 years old.
Old Jan 26, 2015 | 01:00 AM
ibidu1's Avatar
ibidu1
Sounds like you may have popped the main fuseable link
Whats the voltage coming out of the battery?
Old Jan 30, 2015 | 05:17 PM
1supra's Avatar
1supra
having the same issue,battery is only a couple months old,voltage is good lights work,when the start button is pressed,it turns lights on and makes a strange elec noise,doesnt sound like a starter solenoid click though,starter wont turn at all. car has 97k im assuming starter or starter solenoid is bad,any other ideas?
Maxwell123
Jun 20, 2019 09:58 AM
Gee2anIS
IS F (2008-2014)
13
May 1, 2014 07:14 PM
clynnh1230
Jul 18, 2013 05:28 AM
Rustito
Jan 7, 2013 10:37 AM
johnnunez2
Oct 26, 2011 04:25 AM
