lost then found gas cap...Check engine/vac light now on
Old 01-30-15, 12:05 PM
prettyken
prettyken's Avatar
Default lost then found gas cap...Check engine/vac light now on
I have a 2006 gs. I went to the gas station left the gas cap didn't know till the next day. So I went back got the gas cap. Now my check engine and vsc light came on.. Also a light beside the check engine light came on... It's a exclamation mark with a circle around it and parenthesis around the circle. Heelllppppp! Will these lights go off automatically or do I need to have them turned off.. Lexus said eventually they will turn off.. But idk helppppp it just happened on Tuesday...
Old 01-30-15, 06:02 PM
KingAmen
KingAmen's Avatar
It won't reset by it self because the system has detected an evap leak cause by the gas cap being off. You have to manually pull the code and rest it with the OBDII scanner ( you can get one from any auto store ) and it should clear all the lights on the dash. Drive the car for a certain amount of mileages and the system will automatic recheck to see if there is a problem. Good luck and let us know what happens
Old 01-30-15, 06:10 PM
burny
burny's Avatar
go to advance auto or auto zone and have them clear it for you for free
Maxxxx
10-24-18 05:43 AM
brock125
04-18-09 01:32 PM
Antphilli
08-20-08 10:42 PM
jlawr
02-15-08 10:51 AM
tfischer
08-19-05 07:06 AM
Quick Reply: lost then found gas cap...Check engine/vac light now on
