screen keeps going off..anyone know why?
Old May 5, 2014 | 01:16 AM
kazuto88's Avatar
kazuto88
Default screen keeps going off..anyone know why?
So my screen has been acting up for a while now...not too sure why. I have an '08 350 without navigation. From time to time, the screen will automatically go off regardless of what's being viewed. I took a look and fooled around with some settings (the auto transition from climate to trip or whatever you call it) even tried pushing the screen off button in hopes it would reset or clear the problem. Does anyone else have this issue? It's just annoying because I have to constantly re-awake the screen only to have it happen again moments later...
Old May 5, 2014 | 03:46 AM
XxGoKoUxX's Avatar
XxGoKoUxX
Did you turn off auto transition, and flip through two or more menu's to try and disable the screen turning off?
If that doesn't work, maybe a battery reset MIGHT work. Not 100%, but it's worth a try
Old May 5, 2014 | 07:33 AM
2008gs460's Avatar
2008gs460
Do you have polarized sunglasses on when this happens by any chance? If so, rather than waking it up just move your head/angle to the screen and see if it comes back.
Old May 5, 2014 | 02:11 PM
Steve2424's Avatar
Steve2424
There's an option in the display menu that allows you to switch the screen to "off." This might be the case to which you have to toggle it off/ disable the feature, and select 'ok' so that it saves it. Hope this helps
Old May 8, 2014 | 04:55 PM
kazuto88's Avatar
kazuto88
auto transition is turned off and I already tried toggling the screen off feature. clicked ok but it's still happening...argh sooooooo annoying...
Old May 8, 2014 | 06:25 PM
BinaryJay's Avatar
BinaryJay
Happens to mine if the battery is extremely weak - even if it can still start. Charge/replace the battery and all sorts of gremlins are prevented in the GS.
Old May 8, 2014 | 09:30 PM
XxGoKoUxX's Avatar
XxGoKoUxX
This is where a multimeter comes in handy .
Old May 9, 2014 | 06:39 PM
kazuto88's Avatar
kazuto88
it's a brand new shuriken battery...barely a month old.. >.<
Old May 9, 2014 | 08:43 PM
XxGoKoUxX's Avatar
XxGoKoUxX
eh, shuriken or not, they could send you bad batches, it happens to every company .
Optima sent me a batt that was loaded @ 12.3v.
Old May 16, 2014 | 01:12 PM
mr3gs300's Avatar
mr3gs300
funny thing this just happened to me recently, when I was going thru the radio I had clicked the screen off by accident, and ever since then it goes off by itself, very annoying
Old May 18, 2014 | 11:02 AM
designo's Avatar
designo
Common problem, if you're out of warranty, you're $h*t outta luck boys!
mss1234
19
Jun 3, 2023 05:27 AM
eeMatt
May 28, 2021 06:52 AM
eun4u
Jun 2, 2015 06:26 PM
pat70
GX - 1st Gen (2003-2009)
Dec 30, 2009 09:42 PM
