Interior Light
Old Jun 25, 2013 | 11:27 PM
Robertcave's Avatar
Robertcave
Default Interior Light
Hi all
Can brighter LED bulbs be replaced in the interior light and how does the holder come out to replace them
Thanks
Old Jun 30, 2013 | 01:29 PM
morganc's Avatar
morganc
If you're talking about replacing the existing LED lights that are already there, then there's some things holding you back.
The LEDs in that car will be either Pulse Width Modulated (PWM) or current controlled through a transistor to obtain variable brightness. You can remove the existing LED, verify its Vf (forward/turn-on voltage...PM me if you want to know how) and buy a new LED with the same Vf that will output more Lumens of light....
THE PROBLEM lies in the fact that your brighter LED will have to draw more current and its highly possible that a higher-current load would damage the LED drive circuitry. Since we're not Lexus, we have no idea of knowing what that rating is, except by trying it and maybe/not failing.
Old Jul 2, 2013 | 06:35 AM
Robertcave's Avatar
Robertcave
Thanks for that mate looks like its a bit more involved than i thoght
but thanks anway
Old Jul 2, 2013 | 10:44 AM
XxGoKoUxX's Avatar
XxGoKoUxX
most LEDs are 3.7v, if you're looking to replace your dome lights, the 07's and up have brighter LED interior lights.
Old Jul 2, 2013 | 11:35 PM
Robertcave's Avatar
Robertcave
the dome lights the ones above in headlining near the Moonroof switches
Thanks for that
I might see if i can locate one
Old Jul 3, 2013 | 12:01 AM
XxGoKoUxX's Avatar
XxGoKoUxX
NP buddy.... I only know this because my uncle's 07' 450h is much much brighter than in my 06' 430
Old Jul 3, 2013 | 05:20 AM
worker's Avatar
worker
I wanted to create a backlight for that control panel. At night it's so hard to turn on the light when you can't see the buttons.
Old Jul 3, 2013 | 01:55 PM
XxGoKoUxX's Avatar
XxGoKoUxX
You're not the only one worker, fortunately I have good memory, so I feel around and poke the left or right lump hahaha
Old Jul 4, 2013 | 09:00 AM
morganc's Avatar
morganc
3.7V is a huge generalization. 2.4 - 3.7V is a more acceptable range, and again, it comes down to the current rating of the drive circuitry that becomes the limiting factor.
Old Jul 4, 2013 | 01:40 PM
worker's Avatar
worker
I thought a simple low profile LED in the back would light up the crack areas at night, but I tried shining my super bright LED inside and those crack areas didn't light up. In complete darkness and none of the light from the flashlight light up the cracks.
One of these days I will open it up and see if some drill holes could help. My Camry '07, the clear light cover is the button and it's huge so very easy to press it in the dark. Our Lexus light buttons are lump size, a bit more difficult to find in the dark. LOL
DJ TANTRA
Lighting
57
Apr 7, 2015 04:26 PM
XenonDepot
Club Lexus Vendor Marketplace
317
Sep 25, 2014 01:17 PM
mbz560
Oct 23, 2012 11:04 AM
minnister
Jan 3, 2009 10:12 AM
