Active Headlights...??
Old Nov 13, 2012 | 03:43 PM
dekidex's Avatar
dekidex
Default Active Headlights...??
Do we have these on our cars,or was i just tripping tonight....i could have sworn they were moving ...
Old Nov 13, 2012 | 04:08 PM
worker's Avatar
worker
nooooooooooooooooooooooooooo.
(because I can't reply a short no)
my '06 only go up/down during start... why they bother doing that idk. kinda like saying "look here, you have HID." LOL
Old Nov 13, 2012 | 04:11 PM
dekidex's Avatar
dekidex
Default ...
when i did the search i keyed in wrong words,so nothing really came up...but after typing adaptive headlights,i found out that some of the GS models do have the Adaptive Lights....pretty cool.
Old Nov 13, 2012 | 04:18 PM
worker's Avatar
worker
^ how is it active? the up and down kind of active?
Old Nov 13, 2012 | 04:29 PM
twylie's Avatar
twylie
they all self adjust at start up for load leveling.
If you have an AFS button in the left drop down switchpanel, you also have adaptive lighting that turns a bit right and left to help shine "around" the corner as you turn.
Old Nov 13, 2012 | 04:52 PM
worker's Avatar
worker
I wanted to make my own active lighting... do a relay to the turn signal to turn on an extra light. Kinda like a backup light but on the sides in the front instead.
Old Nov 13, 2012 | 05:15 PM
OH-MAN's Avatar
OH-MAN
My 08 does, they move side to side as well when turning at above say 30mph.
Old Nov 13, 2012 | 05:31 PM
Simmsled's Avatar
Simmsled
Not so sure about this. Mine has the button, but the "AFS" light does not illuminate when I start the car (in the instrument cluster). The button is illuminated, however, when the pod is open and the lights are on. When the car is on, the button does nothing. I also have the headlamp washer button but no pop-up washer in the trim ring around the headlamps. Weird.
Old Nov 13, 2012 | 05:49 PM
bigblack06's Avatar
bigblack06
Yes we do its called AFS (Adaptive Front Lighting System) They will move side to side in turns and up and down, I've provided a link.
http://www.lexus.com.bh/technology_e....asp?model=All
Old Nov 13, 2012 | 06:38 PM
neurocity's Avatar
neurocity
Not quite my tempo
yup...
All GS450h's came with it... What I was told anyway.
Old Nov 14, 2012 | 08:38 AM
jamodeo's Avatar
jamodeo
My 09 GS460 has it, when I turn, they move with the steering wheel over some set speed, but when I turn the car on, they only go down, then up during the self test (or whatever they are doing). My uncles LS460 goes down, up and angles them towards the center, then widens back out to normal during the self test. Does the 450 do the horizontal self test also or does it only also do the vertical self test when turning on the car? Just curious.
-Joe
Old Nov 14, 2012 | 10:52 AM
Arantant's Avatar
Arantant
I have it...
Old Nov 14, 2012 | 11:20 AM
broken_tsi's Avatar
broken_tsi
My car has it as well.
Old Nov 14, 2012 | 05:17 PM
CAK 500's Avatar
CAK 500
When I was in college, I drove a 1977 Ford LTD that had that feature.
Old Nov 14, 2012 | 05:51 PM
neurocity's Avatar
neurocity
Not quite my tempo
Holy crap that's right. My brother had a LTD... 351ci with a 2 barrel. 8mpg.
The headlights moved via gear on the steering column...I think.
