Intermidiate pipe Exhaust leak 06 GS300 AWD
Old 10-30-12, 07:02 AM
Droberts12
Droberts12's Avatar
Default Intermidiate pipe Exhaust leak 06 GS300 AWD
Went to the Lexus dealership to have a key programed and dealership did a diagnostic check on the car, very bad news exhaust leak need to replace intermediate pipe they quoted $1900 for parts alone. Has anyone had this issue? Where else can the work be done?
Thanks
2006 GS300 AWD
80,000 Miles
Old 10-30-12, 10:26 AM
Boron
Boron's Avatar
If you have a leak in the system, I'd have thought you should have Check on the MID and the associated lights lit up.
If the dash was showing nothing, but they done the diagnostic as a routine thing or part of the programming, and you did have the lights up (but gone now), then it's just been the gas cap not making a full seal.
Just be sure to push down a bit, as it clicks, and you should be grand - otherwise buy a new cap.
Old 10-30-12, 12:42 PM
kels3000
kels3000's Avatar
Yep, something like that, went in to get my oil changed and was looking for a bill around $60 or less, I had no lights or indications. Mechanic came back with recommendation for an Exhaust manifold replacement $2600. I haven't had it fixed yet because that was not on my modification list.
2006 GS AWD Mileage is probably somewhere around 80,000 by now.
Old 10-30-12, 02:35 PM
Boron
Boron's Avatar
If you've nothing lit up on the dash, and your fuel economy is steady (assuming same type of journeys each day), then put it to the back of you mind for the time being.
That and have an independent look at the manifold, see if he has a sniffer or something to detect leakage of exhaust gases.
If the fuel cap not making a complete seal is enough to send the dashboard into overdrive, then I don't think it takes one to be a rocket scientist to extrapolate that the same vacuum the system works under and monitors, includes the exhaust gases out to the cats on each bank, if not the rear cat too.
So, (un)fortunately, I have to call BS on this "discovery" for the time being, and the dealership will have to make do without your financial contribution.
Old 10-30-12, 02:38 PM
mr3gs300
mr3gs300's Avatar
I had an exhaust leak on mine that kept popping an error code for my cats, but took it to dealer they found it was an exhaust leak and fixed it thru warranty, the exhaust and the parts associated have a factory extended warranty
Old 10-31-12, 05:20 AM
Simmsled
Simmsled's Avatar
While this is true, it varies by state. I believe California has the longest warranty on emissions based equipment. Check your manual for specifics!
Old 10-31-12, 10:58 AM
kels3000
kels3000's Avatar
I'm in GA an it does vary by state and possibly who you get your warranty through, because I bought an extended warranty and in the warranty it specifically stated that any part of the exhaust system is not covered. Of course I didn't find this out until I raised the roof.
Old 09-19-13, 06:16 PM
mxbuch
mxbuch's Avatar
Thanks
2006 GS300 AWD
80,000 Miles
Hello I HAD contact with my dealer and since my vsc light was going on and off they hooked it up and informed me that my Y exhaust had a leak and needed to be relaced at $2,000 I bought a new gas cap and the problem may have been resolved.
Also are you aware of the campaign to replace cv boots that are torn.Because of issues Lexus will allow you to purchase an entire axle left and right side at the cost of boots.A framatic savings.
Old 09-19-13, 06:43 PM
ibidu1
ibidu1's Avatar
Common problem on these cars especially for AWD's. Easy solution, take it to a muffler shop tell them too remove the heat shield and both clamps, grind the in between and weld it solid.
The main problem is the dust shields trap dirt and debris and cause rust. Worst case if your piping is too badly rusted you can have him cut that section and weld on a new pipe.
Total cost for me to do one side $30 bucks and 40min waiting
Old 09-20-13, 12:46 PM
BinaryJay
BinaryJay's Avatar
Why replace pipes when exhaust shops will just cut out problem parts and replace with stainless steel?
Old 09-21-13, 04:51 PM
crump06
crump06's Avatar
Same thing happened to me. I had no check engine lights but I could hear a tiny exhaust leak. Then lexus did the misfire replacement for me. I recieved my car back and it was extremely louder. They said it was because the motor was healthier now and its putting out more power since they replaced internals.. Whatever. They said my intermidiate pipe had a leak and wanted over 2 grand. I took my car to an old school muffler shop and he said the pipes had rusted and there were holes. He cut the pipes and replaced them on both sides. It took 30 minutes and 60 dollars because i used a card. It would have been 50 cash. Problem solved, it is quiet again. I don't care if it's not lexus oem. I refuse to pay 2 grand. I'd much rather take that money and put it down on a newer vehicle. My car is an 06 gs awd as well.
Old 10-07-13, 05:24 PM
skillydog
skillydog's Avatar
Well the good news is I know my dealer is at least consistent with all of the other quotes you guys are getting... the bad news is that I gave them the go-ahead to fix it at $1,800 today.... Sucks for me but also for the dealership's new car sales as I was planning on trading in for a 2014 GS when they come out... now I'm going to ride it out and try to get another year out of this one...I just might look at a Jaguar next time...
Old 10-07-13, 08:36 PM
XxGoKoUxX
Forum Moderator
XxGoKoUxX's Avatar
I heard great things about Jaguar... My fiancé's boss drives one and absolutely loves it. I still <3 my Lexus though, so I don't think i'd ever make that kind of a switch.
TBIYTC
09-23-18 09:27 PM
supraman6
03-23-17 06:56 AM
MVNLexus
Performance
17
07-28-16 12:12 PM
Mr4btTahoe
12-08-15 10:44 AM
lexuz125th
05-28-14 01:14 PM
Quick Reply: Intermidiate pipe Exhaust leak 06 GS300 AWD
