Rwd vs Awd
Old Sep 9, 2012 | 09:47 AM
MnGs3xx's Avatar
MnGs3xx
Default Rwd vs Awd
So I've been reading through the forum and it sounds like awd isn't good for lowering and getting wheels is that true? Like for rattles and other minor things too i read. And does the rwd feel like it has more power since it has less weight or are the rwd and awd similar? I have a rwd charger and I'm a big fan of it but rwd versions are a lot harder to come by then the awd thanks for ur help
Old Sep 9, 2012 | 09:58 AM
msgs350's Avatar
msgs350
AWD is not ideal for lowering because it will vibrate when lowered. As for rattles, i believe its the same for both models, some get lucky and get a quiet car. Depending on the part of the country...RWDs are plentiful, especially in Cali. Good luck!
Old Sep 9, 2012 | 11:49 AM
Simmsled's Avatar
Simmsled
AWDs generally hold their value a bit better.
I've driven rwd and awd and feel that you really don't pay any driving-fun penalty with awd.
Old Sep 9, 2012 | 01:22 PM
MnGs3xx's Avatar
MnGs3xx
So on the awd do you get vibrations with aftermarket wheels or do they only get vibrations when you lower the car?
Old Sep 9, 2012 | 01:27 PM
msgs350's Avatar
msgs350
Its when you lower the car.
The lower you go, the worse it is. It's also more noticeable in colder weather.
Old Sep 9, 2012 | 05:57 PM
MnGs3xx's Avatar
MnGs3xx
Is there's a reason for it? I understand that it happens but I don't get why? I'm steering towards rwd but there are so many more awd s to choose from..
Old Sep 9, 2012 | 07:50 PM
msgs350's Avatar
msgs350
We suspect that, after lowering, the axles sit at an "angled" position. This issue has been brought up MANY times! Here is a link to a thread that relates to this issue.....
https://www.clublexus.com/forums/sus...rs-needed.html
Old Sep 10, 2012 | 03:39 PM
ADI$A69's Avatar
ADI$A69
i beg to differ on that point. I've been in the market for several months, and I consistently see an abundance of AWD models, selling for thousands less than comparably equipped RWD models. all else being equal, mileage etc, the AWD models are easier to find, and cheaper.
Old Sep 11, 2012 | 08:21 AM
Simmsled's Avatar
Simmsled
I guess it must be snow belt states then. In Indiana, the AWDs are more expensive than the RWDs. I know eBay is loaded with AWDs.
Old Sep 11, 2012 | 01:27 PM
IXI187IXI's Avatar
IXI187IXI
its because of location. they are cheaper down south because AWD isnt needed as much as it is up north, hence why they are more expensive up north.
Old Sep 11, 2012 | 10:39 PM
MnGs3xx's Avatar
MnGs3xx
so what would any of you suggest rwd or awd?, im stuck i really want the rwd but so many awd's to choose from and there better deals on the awd's also in the lower states, outside color doesnt really matter to me but i need black leather cuz in mn it can get messy with the snow and slush..
Old Sep 12, 2012 | 04:46 AM
msgs350's Avatar
msgs350
If you don't need the AWD, don't get it ....... especially if you plan to modify the suspension. I personally would've bought a RWD but needed the AWD in Washington state.
Btw....RWDs look better because the front sits lower than the AWD from the factory
S2KBobby
RC - 1st Gen (2015-present)
Jan 5, 2019 08:25 AM
Sk8Surfr
Jul 1, 2011 07:15 PM
vader11
Nov 6, 2006 02:37 PM
idg
Feb 17, 2005 07:18 AM
