I noticed while waiting for my friend outside his house for about 20 minutes that the AC was not as crisp. Yes it said 106 F outside but still. Lowering the setting to MAX cold and fan in the middle it got better.
All goes back to normal once you start moving again.
I am wondering perhaps its a bit low on freon.
Can I add a can, like the ones they sell in stores? Where is the low pressure nozzle? I am afraid of overfilling it, so I am gonna do a small can.
Doubt its a leak, just maybe a bit low after 6 years of usage??
Also can with a gauge, know the PSI I should stop at?
Im gonna get the temp gauge and measure the AC temp, I think its supposed to be 40-50F out of vent.
I'd just love to add you are RIGHT on the money with this instinct, I'd love to know the PSI to stop at, I don't care for the yellow/red/green gauge, because all that shows is color, I'm pretty darn sure all A/C systems have an optimal pressure range vs color range .
Plain and simple, the hotter it is outside, the harder it is for the AC system to cool the air. It's just common sense.
A quick and dirty way to check is look for the sight glass usually on the high-side of the system. I don't have a 3GS anymore so I can't tell you where it is exactly. If you see bubbling in the sight glass, then your system could use some service.
Anyhow...so 100F+ today. And again, on HI and MAX COLD idling car blows 55-60F outside the vents. If I put it to Medium, it gets down to 50, and once I start driving it gets between 45-50. Which is not as cold as it should be.
When temps outside are 80-95, all is well. But not in 100+ weather.
So I added a bit of freon and I think it got a little better, but I am afraid to over fill it. Will take it to my shop tomorrow to test the system. I hate going to shops.
Id drop it off at a Lexus dealer buy they will charge me and arm and a leg, and will probably suggest changing everything from compressor to condenser to, sunroof to navigation unit, while they are at it.
Will report back tomorrow.
A bit ashamed, I thought I would never have a single problem with my Lexus. My LS400 had a killer AC.
