Power windows will not work from drivers control panel
I cannot get my front passenger or rear windows to operate remotely from driver control panel. I have cycled the window lock button several times. Any suggestions?
From each of your doors, roll the windows down halfway then back up all the way. This will reset them. You may have to do this with sunroof too. Did you recently disconnect or change battery? You have to reset wundows every time you do so.
You should really search for this as it's been discussed hundreds of times silly!
but alchemist hit it right on the spot.... from each of your passenger windows, push the window down for 2 seconds and right back up instantly for 10+ seconds, let go and it should be reprogrammed..... sunroof i think you hold the open button until the sunroof completely opens and closes itself and it should be programmed for auto-open and auto-close.
I'm a "Newbie" and will check threads in the future. Most likely what I am experiencing has already happened to someone else. I'm just grateful it is a simple "fix".
Again, Thanks
LennGS
Again, Thanks
LennGS
It most certainly is! Welcome to CL by the way Lenn, you'll most definitely enjoy it! Don't forget to cruise by the FAQ thread!
https://www.clublexus.com/forums/gs-...tart-here.html
Ramon
May 31, 2006 01:17 PM
