rearview mirror problem
Old Jul 21, 2012 | 06:18 PM
DrewGS350's Avatar
DrewGS350
Thanks... will do.
Old Aug 15, 2013 | 07:57 PM
DrewGS350's Avatar
DrewGS350
Dealer replaced mirror under extended warranty. Still vibrates when it is hot. Is fine when it's cool. Tightened the hex screw a tad after reading another post. Will see what happens tomorrow.
Old Aug 15, 2013 | 09:20 PM
XxGoKoUxX's Avatar
XxGoKoUxX
Wow drew, you finally got around to it after a year? lol
GL on the issue! Mine's is gone now that I've removed my 2 12's.
Old Aug 16, 2013 | 10:33 AM
DrewGS350's Avatar
DrewGS350
Dealer was unable to duplicate until now. Still having the problem though. So when you say you removed your 2 12's what does that mean?
Old Aug 16, 2013 | 10:34 AM
DrewGS350's Avatar
DrewGS350
Anyone had this problem start after replacing their windshield?
Old Aug 18, 2013 | 09:16 AM
XxGoKoUxX's Avatar
XxGoKoUxX
The problem went away after I removed my 2 12'' subwoofers.
It was still apparent when I had my 10'' too, but after 2 mirror replacements the problem was gone.
Did you happen to at all have your mirrors replaced?
Old Aug 18, 2013 | 02:00 PM
DrewGS350's Avatar
DrewGS350
No just the windshield. It all started exactly when the windshield was replaced. No issues with the rearview mirror until then.
Old Aug 18, 2013 | 02:18 PM
XxGoKoUxX's Avatar
XxGoKoUxX
Hmm, how bad does it shake? Maybe you can put a piece of paper between the ball joint to give it a little more pressure from moving? (a black piece of paper preferably so it doesn't stand out.
Old Aug 25, 2013 | 07:48 PM
DrewGS350's Avatar
DrewGS350
Saw that as a fix on another forum. Honda Civic I believe. Similar issue. Keeping it in mind. It only happens when its hot. After I turn on the AC and the car cools down it stops. Weird...
Old Aug 25, 2013 | 11:33 PM
XxGoKoUxX's Avatar
XxGoKoUxX
I'm sure the reason behind that is due to the heat expansion, while it expands, It's actually suppose to make it harder to move the mirror, but I guess in your case it somehow makes the gap larger, making the mirrors twitch more..... Have you considered taking the mirror apart to see if there's anything you could do?
Old Aug 26, 2013 | 04:22 AM
bigblack06's Avatar
bigblack06
Yes I had this problem, with my GS 300 by I had a lot of problems with it even after they replaced it.
Old Aug 26, 2013 | 08:04 PM
DrewGS350's Avatar
DrewGS350
I believe the problem is the windshield. The mirror was replaced and this all started after the windshield was replaced.
Old Aug 26, 2013 | 09:21 PM
XxGoKoUxX's Avatar
XxGoKoUxX
This really bites, wish I was there to help ya bud, but I'm in FL and you're in TX lol
Old Aug 28, 2013 | 06:57 PM
BLAZE's Avatar
BLAZE
There is a thin piece of plastic in the ball joint of the mirror, when its hot it becomes soft and it creates play in that joint. It's like a ball and socket. Once it cools it becomes stiff and regains tension. If the mirror is tight to the mirror button that is attached to the glass, it simply has nothing to do with the glass.
Take your index finger and thumb and with both hands, lightly wiggle the the outer shell. You can see the play in the joint. It mostly happens in the hotter states. The fact that it is happening to the new mirror as well, tells you that the glass tech didn't break the old one.
Maybe try that paper trick or crazy glue, if you are the only driver. Good luck either way. I can see how annoying that can be.
Pearlpower
Sep 4, 2022 03:25 PM
redsoxfan6
Mar 21, 2019 09:21 AM
hriewe
May 10, 2013 09:29 AM
alaucke
Mar 28, 2008 03:33 PM
tritron
May 18, 2007 07:59 AM
