center switch console
Old Jan 18, 2011 | 04:46 PM
*Batman*'s Avatar
*Batman*
Default center switch console
Does anyone know how to dismantle the center switch console? Any step by step would be useful.
I want to know what it takes to install the aluminum trim console.
Old Jan 18, 2011 | 04:57 PM
passnu2's Avatar
passnu2
off topic but isnt that a switch to shut off the headlamp washers?
I dont think you have to take anything apart. Maybe just lift the center piece and that is in the DIY navi thread.
Old Jan 18, 2011 | 05:53 PM
rominl's Avatar
rominl
exclusive matchup
very simple. pull up shift plate (straight up) and slide it out, disconnect connectors. 2 screws, one on each side leather panel, then pull it out. the button console is held down by clips around it, work your way through, unclip, and pull it up
Old Jan 18, 2011 | 06:00 PM
mrblack's Avatar
mrblack
Yes the four corner areas even have a rectangle cut out you can put a flat head screw driver in to help pull up on.
Old Jan 18, 2011 | 06:11 PM
GS350Lexus's Avatar
GS350Lexus
Batman I think that aluminum trim console doesn't flow with anything in the car?
Old Jan 18, 2011 | 06:14 PM
IXI187IXI's Avatar
IXI187IXI
If you update the plate for the shift indicator i think it will match pretty well
Old Jan 18, 2011 | 06:16 PM
*Batman*'s Avatar
*Batman*
The trim around the nav screen.
Old Jan 18, 2011 | 06:45 PM
CAK 500's Avatar
CAK 500
Definitely some interesting items on that website, bats. Is there a North American distributor?
Old Jan 18, 2011 | 07:41 PM
*Batman*'s Avatar
*Batman*
I don't think so. You have to find someone in Japan to send it to you.
AL13NV8D3R
Jan 14, 2016 02:01 PM
t2d2
Aug 13, 2014 06:05 PM
leadfoot83
Feb 7, 2013 06:44 AM
JasonGS
Sep 9, 2009 09:56 AM
slevytam
19
Mar 1, 2007 07:03 PM
