Programing key fob help
Old Nov 21, 2010 | 07:50 AM
Dempsey220's Avatar
Dempsey220
Default Programing key fob help
New to the forum, just bought a 2006 gS430, my problem is it only came with one key fob and it's missing the valet key. I was curious if I bought a key fob ifi was able to program it myself
Thanks in advance for any help
Old Nov 21, 2010 | 08:56 AM
*Batman*'s Avatar
*Batman*
No only dealer can program fobs, and to program one you have to re-program all since they are synced.
Also if you buy a key fob online, note that there are several FCC-IDs used on Lexus keys (they are not all the same). So check you buy a key with the same FCCID. The FCC ID is printed on the front of the key fob.
Also there is no such thing as a Valet key. You probably mean the metal key insert for the fob. You can order those from lexus.sewellparts.com at a reasonable price. However note, that this only helps open the door if the battery is completely dead. You can't start the car with it.
Old Nov 21, 2010 | 09:24 AM
Dempsey220's Avatar
Dempsey220
So i would have to buy a key fob with the same FCC I'd #? Once I get one then bring both fob to the dealer to be programed? As far as the metal key does the dealer cut that to or can any locksmith cut it for me?
Thanks again
Old Nov 21, 2010 | 11:12 AM
swtjlsy's Avatar
swtjlsy
Thanks again
Thats right only the dealer can program them no one else.
Old Nov 21, 2010 | 04:31 PM
*Batman*'s Avatar
*Batman*
Thanks again
A high end locksmith like Home Depot or Loews should be able to cut the key insert. You can buy them on ebay for $10. Or you can buy a pre-cut one shipped directly from Lexus through Sewell Lexus for $54.73.
Regarding the fobs, take all your fobs at once to a dealer. I would call around and offer them 30 minutes of labor for the job ($60). Some dealers charge a full hour ($120).
Old Nov 23, 2010 | 10:29 AM
LexusVRGN's Avatar
LexusVRGN
I did have to buy a new key from Lexus to insure that it worked. I had been told that a used one would work and that they could reprogram. This is incorrect.
Old Nov 23, 2010 | 05:11 PM
bigjohnsd's Avatar
bigjohnsd
I had my key cut at a Lexus dealer, but i had the FOB programmed at a Toyota Dealer that was much closer, and much less expensive too.
Old Nov 23, 2010 | 09:31 PM
username32's Avatar
username32
FYI, you can simply just have the remote programmed to use it, you don't have to cut the key. In fact the key can be left out or left blank and uncut.
Old Nov 23, 2010 | 09:40 PM
LB23's Avatar
LB23
Is this common for all smart keys?
Because it sends a signal to the computer....?
Old Nov 23, 2010 | 09:43 PM
username32's Avatar
username32
Yes but, even if the car had a traditional key setup it still wont start if you have a completely dead battery.
Old Nov 24, 2010 | 04:12 AM
IXI187IXI's Avatar
IXI187IXI
if your battery is dead, you can still get into the car. my battery was dead about a week ago from sitting for so long but i didnt have a problem opening my doors with the fob.
Old Nov 24, 2010 | 04:42 AM
*Batman*'s Avatar
*Batman*
It all depends how dead. If totally dead then it won't work. In most instances fob will work but not enough power to crank engine.
Old Nov 24, 2010 | 05:44 AM
IXI187IXI's Avatar
IXI187IXI
My battery was completely dead, no click or anything when i pressed the start button,
Old Nov 24, 2010 | 03:37 PM
*Batman*'s Avatar
*Batman*
But cant have been as dead as mine. In my case doors wouldn't open either. Had to use the key insert inside the fob.
Then the AAA guy couldn't start the car with the regular booster battery so he had to get a heavy duty truck booster battery.
2jzdc
Nov 1, 2018 08:37 PM
Dolphin
Canada
Jul 31, 2013 12:34 PM
yolnerd
Nov 9, 2009 07:03 PM
Justakid
Maintenance
Jun 24, 2009 06:33 PM
