A/C air filter change help
Old Aug 31, 2010 | 03:43 PM
Brian06's Avatar
Brian06
Default A/C air filter change help
Hello,
I chaned my a/c filter a few weeks ago, and the past couple weeks I have been getting a gasoline smell coming inside the car when i turn the a/c on.
I follwed the directions on here on changing the filter, but I think I might have damaged that little door. An advise would be great.
Thanks
Old Aug 31, 2010 | 03:55 PM
BinaryJay's Avatar
BinaryJay
I don't think the gas smell and the air filter, broken door or not, would be related.
Could be a coincidental exhaust leak, is your car sounding louder than it used to?
What makes you think you damaged it if you followed the directions? You just popped off the outer cover after putting the car in recirculate mode right? Filter just pops out from there, there shouldn't have been any more doors in the way.
Old Aug 31, 2010 | 05:08 PM
Brian06's Avatar
Brian06
Thank you for the reply.
I actually had to force the little door for the a/c filter open. When I click on re-circulate button, I can hear the gears moving, but it seems that something os off in there. When I open the outher cover, the door is not completley closed
Old Aug 31, 2010 | 06:46 PM
jtrue28's Avatar
jtrue28
I think you may have broken that door. That's a very expensive mistake.
Old Sep 1, 2010 | 12:08 AM
rominl's Avatar
rominl
exclusive matchup
umm..... that doesn't sound good at all..... if you had to force the door open, that doesn't sound right
Old Sep 1, 2010 | 04:15 AM
BinaryJay's Avatar
BinaryJay
Even if his recirculation door is broken, he shouldn't be smelling gas in the cabin and should be looking at an exhaust leak or worse. Agreed?
Old Sep 1, 2010 | 10:52 AM
rominl's Avatar
rominl
exclusive matchup
oh yes, i agree that has nothing to do with gas smell. but probably coz' the door is broken, maybe it's getting fresh air all the time and whatever outside (could be OP's car or other cars around) gets in
Old Sep 1, 2010 | 11:08 AM
BinaryJay's Avatar
BinaryJay
Right... I guess there's not enough information. Does he smell it all the time, or just when he's stopped at a light behind a 20 year old civic with fart can exhaust tips, rusted muffler, and missing catalytic converter?
Old Dec 13, 2011 | 01:38 PM
moose66's Avatar
moose66
Moderators, can this post be taken out of this thread to start a new one to help the OP get an answer? It is quite obvious it was posted to an unrelated topic.
iowadawg
HS 250h Model (2010-2012)
Mar 22, 2015 02:31 PM
Cut-Throat
Apr 7, 2013 09:59 PM
Languistic
CL of Southern California
Feb 27, 2012 09:48 AM
Brian06
Jan 21, 2011 03:01 AM
Joeb427
Sep 7, 2007 03:30 PM
