Door lock question
Old Jul 10, 2010 | 04:40 AM
avfs313's Avatar
avfs313
Default Door lock question
Hi all,
I have use the serach function and no help. I hope someone could help me.
I have a 2007 gs350 and would like to know if I can program the door lock to lock when I shift the gear to "Drive"? I had the IS350 and it automatically locks the door when shift to drive.
Also, when I unlock the doors on my gs. It only unlocks the drivers side but for my IS you can program it to unlock all.
Thanks for the help guys!
Old Jul 10, 2010 | 05:10 AM
twylie's Avatar
twylie
For US market vehicles, both settings are user adjustable and described in the manual under the Doors and Locks section. Check the hardcopy manual for procedures or it may be available online once you register with lexus.com under the owners section.
edit: was able to paste it in from online manual
CHANGING THE DOORS TO BE UNLOCKED
When you push the “LOCK” button together with the “UNLOCK”, “TRUNK” or “PANIC” button on the electronic key for about 5 seconds with the engine switch off, you can change the settings for door unlocking.
Each time you push the buttons, the multi−information display and setting changes as shown.
Driver’s door unlocking mode
The setting displays flash alternately for 4 seconds. When the setting is complete, you will hear the following:
3 beeps (Outside), One chime (Inside)
This mode allows you to unlock only the driver’s door when you hold the driver’s door handle and all the doors when you hold any door other than the driver’s door handle.
Side doors unlocking mode
4 beeps (Outside), One chime (Inside)
This mode allows you to unlock the front and rear doors on your side when you hold any door handle.
Single door unlocking mode
The setting display changes as shown. When the setting is complete, you will hear the following:
One beep (Outside), One chime (Inside)
This mode allows you to unlock the door for which you hold the door handle.
All doors unlocking mode
The setting display comes on for 4 seconds. When the setting is complete, you will hear the following:
2 beeps (Outside), One chime (Inside)
This mode allows you to unlock all the doors when you hold any door handle.
The display will return to driver’s door unlocking mode when you attempt to change the setting from all doors unlocking mode.
INFORMATION
If you get in the vehicle from the driver’s door using an electronic key while the side doors or one door is set to be unlocked, all the unlocking controls activated by the electronic key will be stopped for security. If you get out of the vehicle from the driver’s door carrying the electronic key and reaches out of the effective range of the entry function, unlocking control by the electronic key will be possible. However, unlocking control may not be carried out for 5 seconds after you get out from the vehicle. In this case, perform unlocking operation again after 5 seconds.
Automatic door locking and unlocking functions
AUTOMATIC DOOR LOCKING
You can select the following functions:
Locking linked with the shift position
All doors are automatically locked when the selector lever is moved out of “P” position.
Locking linked with vehicle speed
All doors are automatically locked when the vehicle speed
goes above about 20 km/h (12 mph).
You can set or cancel the automatic door locking functions:
Be sure to apply the parking brake when performing the following operations.
To select the locking linked with the shift position:
1. Close all doors and select the engine switch in “IG−ON” mode.
2. Shift the selector lever to the “P” position.
3. Within 10 seconds of selecting the engine switch in “IG−ON” mode, press and hold the driver’s side power door lock switch in the lock position for 5 seconds and then release.
The doors will be locked and unlocked to indicate that the function is set.
To cancel the function, do the above operation again.
KEYS AND DOORS
To select the locking linked with the vehicle speed:
2. Shift the selector lever from “P” to the “N” position.
Old Jul 10, 2010 | 05:50 AM
avfs313's Avatar
avfs313
Tahnk you so much for the quick response!! Thanks again!!
jeeper2269
Dec 11, 2016 11:11 AM
jlin101
Aug 5, 2016 08:06 AM
Silver06GS
Mar 14, 2010 02:38 PM
Mike_TX
Jan 9, 2008 07:42 AM
nhey
Feb 26, 2007 07:11 AM
