Black Exhaust?
Old Jun 27, 2010 | 08:06 PM
Mike450h's Avatar
Mike450h
Thumbs down Black Exhaust?
I have noticed after only a couple days driving after I have cleaned my exhaust tips, they are black. I go to the dealer as it was on my way home one day, went to the service dept, asked one of the tech's about it, he tells me this is normal? I explain the car has less than 10K miles on it and that can't be normal for black smoke to be blowing out of a motor that is basically new! Its a very black carbon. I am familiar with a motor that is running a bit rich and getting to much fuel...
Anyone have any ideas? before I take it back to the dealer and demand results, I don't want to have to clean my exhaust tips daily.
Mike
Attached Thumbnails Black Exhaust?-black-smoke-001.jpg   Black Exhaust?-black-smoke-002.jpg   Black Exhaust?-black-smoke-003.jpg
Old Jun 27, 2010 | 08:11 PM
SNiiP3R's Avatar
SNiiP3R
I have the same problem...Exhaust gets dirty after a few days. I installed the exhaust last year, when the car only had 5,500 miles. So, I think its normal.
Old Jun 27, 2010 | 08:12 PM
Bushwack's Avatar
Bushwack
Once your tank is near empty, fill up using different gas. Not sure it would make a difference. I have heard that Chevron gas is known to produce carbon build-up (over time).
FWIW, I change gas suppliers every month. Usually split between Unocal, Shell and Exxon.
Old Jun 27, 2010 | 08:14 PM
spine911's Avatar
spine911
sorry to hear bout this occuring on your 450h ....
...this is exactly how i first determined that the 3gs are prone to Carbon Buildup issues...least to say on the 300s/350s....this is definitely abnormal for a gasoline DI engine to have this amount of buildup-my VW TDI (Direct Injection Turbo Diesel) produces less tailpipe buildup.
https://www.clublexus.com/forums/gs-...ml#post5520797
..after i initially noticed this tailpipe buildup-i knew something is up.....hate to say i was the 3GS Carbon buildup whistle blower
TSIB info. for the 300 platform.
https://www.clublexus.com/forums/gs-...-build-up.html
Old Jun 27, 2010 | 09:35 PM
designo's Avatar
designo
My car is running rich ( 9:1 ). If you can check the A/F ratio, please do so and report back.
Old Jun 27, 2010 | 10:05 PM
Mike450h's Avatar
Mike450h
A/F ratio? ok if you can tell what that is?
Old Jun 28, 2010 | 07:13 AM
gridlock13's Avatar
gridlock13
A/F ratio = Air to Fuel ratio
Old Jun 28, 2010 | 08:48 AM
Mike450h's Avatar
Mike450h
Got it...Thanks
Old Jul 1, 2010 | 06:12 PM
spine911's Avatar
spine911
to the OP,
decided to resurrect your post since there is already a possible recall (infancy stage) set to repair the valve springs which is a possible** fix for the carbonization.
goodluck.
Isn't it an irony..... what's the point of driving a smoke belching "green" hybrid machine.
Lexus should step up to this issue bigtime ;(
Old Jul 1, 2010 | 06:33 PM
Chancellor's Avatar
Chancellor
Its normal mine does it too. Just dont leave it on there to long.
Old Jul 1, 2010 | 07:19 PM
passnu2's Avatar
passnu2
interesting? I never had this issue on my IS350 or my GS430.
Old Jul 1, 2010 | 08:54 PM
spine911's Avatar
spine911
i still have to see a gs430 which has the carbon buildup issue.
the IS350 is already part of this developing valve spring recall.
as i mentioned previously; i initially noticed the carbonization trend on the 300/350s, NOT on the 430s....of course it was not a scientific study, but i guess my suspicion was further solidified by this recent pending valve springs recall (which is ONE of Lexus's fix for carbon buildup).
Old Jul 2, 2010 | 05:48 PM
Mike450h's Avatar
Mike450h
That amount of carbon after only a couple days of driving can not be normal for any motor, something has to be up, been a car guy all my life and have only seen this amount of carbon on motors that have serious issues.And on a motor that has less than 10k miles on it? no way...
Old Jul 2, 2010 | 07:18 PM
I8ABMR's Avatar
I8ABMR
do you shift at near red line. The motor will dump a lot of fuel at high rpm
Old Jul 2, 2010 | 07:33 PM
LexFather
Guest
Posts: n/a
Not noticed on my 450h, 400 or 430....there is normal carbon usually the worst at the bottom center of the tips..
How often do you drive your car?
