I need spacers
Old Apr 15, 2010 | 04:45 PM
telmz1's Avatar
telmz1
Default I need spacers
The front of my rims are 20 x 8.5 +38 with 245/30. When I measure from the gap between the side wall of my tire to the inner fender, I get 35mm. Can I put in a 20mm spacer?
Old Apr 15, 2010 | 05:40 PM
rominl's Avatar
rominl
exclusive matchup
you will effectively make it 8.5 +18, that's pretty aggressive
you will likely rub the lower part of the fender unless you do a lot of modification in those areas
Old Apr 15, 2010 | 05:45 PM
telmz1's Avatar
telmz1
thanks Rominl. What size spacer would you recommend? I'm guessing a 10 mm spacer?
Old Apr 15, 2010 | 06:03 PM
rominl's Avatar
rominl
exclusive matchup
what kind of look you looking for and what kind of work you willing to do?
Old Apr 15, 2010 | 06:20 PM
telmz1's Avatar
telmz1
i want to try to get the front to match the look of the rear. I followed your DIY a while back because I was running overspec tires. That's all I really want to do with the fenders.
My overall goal was to get front spacers that will work with both my existing rims and my stocks since I want to use the ichiban V2. However to do that I will need to trim down my OEM studs since the back of my rims are flat.
Old Apr 15, 2010 | 11:09 PM
rominl's Avatar
rominl
exclusive matchup
well to give you an idea, you have 8.5 +38. i have 9 +37, which is the same as 8.5 +31 (outboard wise). so you know if you put a 7mm spacer up front, you will be close to what i have (considering we have the same size tires)
now on my front, i know i can probably go another 5mm or so, but my ride height is becoming a problem (you can look at pics of my car to see how low it is) and i will start to rub quite a bit more, especially around the 10 and 2 oclock positions. the problem will worsen when i am doing turns. at my current setup, if i am turning at higher speed and hit a bump, i almost guarantee a rub.
so you kind of get the idea there and see how much you want to try to push it out
Old May 12, 2010 | 03:59 AM
mr3gs300's Avatar
mr3gs300
rominl is the man he always answer questions simply, so the average guy can understand what needs to be done, way to go guy
Old May 12, 2010 | 04:27 AM
IXI187IXI's Avatar
IXI187IXI
yea henry is good for wheel and tire questions. knows his ish
Old May 12, 2010 | 06:27 AM
designo's Avatar
designo
I have a similar question, but will open a seperate thread if you guys don't mind. I think your offsets look okay, but you can go another 10 or 15mm no problem.
Old May 12, 2010 | 08:47 AM
rominl's Avatar
rominl
exclusive matchup
thanks for the kind words guys, i am happy to help!
Old May 12, 2010 | 01:55 PM
designo's Avatar
designo
Romini.. we love you!
Old May 12, 2010 | 02:09 PM
TWong350's Avatar
TWong350
CL Folding 10,000
Yes, we all love Henry!
Holy cow! Those windows are DARK!
Old May 12, 2010 | 03:58 PM
telmz1's Avatar
telmz1
Henry IS the man!! It looks darker in the picture than it really is. My front is tinted...its a must out here in the Vegas desert.
Old May 12, 2010 | 05:40 PM
passnu2's Avatar
passnu2
Henry I thought you were 9 +34? Not 9 +37 up front.
I was running 9 +35 up front with a 255/30 tire. I had rubbing in the spots that rominl posted in his DIY fender mod thread. Now that I am lower its a pretty big issue. 245 would help a little bit. I plan to push it more so will see how it works out being so low.
Mr Mark is running 9.5 and I believe +31 up front but he did pull his front fender.
Old May 12, 2010 | 05:55 PM
rominl's Avatar
rominl
exclusive matchup
ooops, mike is right, thought wrong. i have 9 +34 front. +37 is my rear 10" setup
mike i think you are rubbing the bracket location just like eric in FL right? that's one very tough spot
