Limiter on my CAR =0 !!!
Interesting. I just looked this up on Wikipedia. The normal GS460 engine is the 1UR-FE while the LS460 has the 1UR-FSE. The difference is the LS has direct injection which gives it 380hp vs 342hp.
In the middle east the LS comes with the GS engine so it only has 342hp. I suspect Lexus is deliberately detuning the GS engine to create a difference (i.e. its Lexus not the dealer). Given this you could either write to Lexus and complain, or just get the US ECU which will tune it back to 342hp.
there's also risks in doing this besides warranty.... like fitment (no one is 100% that this is plug and play from a USDM spec to MEDM(middle eastern domestic motors?) spec
the wiring diagram may be different between a US version and yours.... so i'd do a bit of research before i jump on this project...also you're not guaranteed that you will get 342 out of your vehicle.... there's not only the mappings of your ECU, but the engine settings, like cams, injectors, pistons, etc etc. that can slightly be changed to compromise for the power loss.....
on the upside, you'll be a legend cuz you'll me the first to do eeeet (if successful)
Lol, after reading your post, my determination to go through this actually decreased substantially hehehe. I guess i'll stick with me 322 after all :/. Dont know if I should mention this here but I actually found out about my -20 HP after an Infiniti G35 passed me which was really weird >.<... hehehe
and about the G35... you shouldn't be ashamed... our cars? they're PIMPMOBILES! not dragsters... in my opinion anyways... the GS's are heavy vehicles, because they're loaded with a lot more **** than anything... if u wanna compare, u should be comparing to a M35/45 hahaha.... us 430's lose to them, but... i'm sure a 460 will hold it's ground
don't you guys use higher octane ratings? lol we use 87 89 and 93.... might be why you're 307 vs us 303
they do this to lower class US-spec cars.... a "JDM" B18 would always be faster than a "USDM" B18.... mostly because of engine internals are tuned differently combined with the ECU having different mappings..... so that's why i said what i said about the ECU might not be hte only thing to unlock those 20 ponies
Could indeed very well be a different method of calculating HP.
If not.... How does the published 0-60mph or 0-100kmh compare to countries where there is 342 hp (255 kW) available (in Europe 5.8 s to 100 kmh)?
My GS300 in Thailand is listed as 228 hp only, while the same GS300 in Europe is 245 hp (183 kW). 0-100 in Thailand is 7,5 s and in Europe 7,2 s. Lexus Thailand denies detuning, but cannot explain the difference either....
surprised you didn't know this one! the higher the octane rating, the higher your timing can go, the higher your timing can go, the moar powah u can get! =] up to a certain point anyways.... after that certain point you need tuning
o wow, really? we all need to band together and petition to get MOAR POWERRR
i cant exactly know the 0-100km/h since our dealerships does not mention them. I tried once and I think I got high 5's low 6's... cant really know the precise number.. Think I'll test and post a video
Interestingly GS300 in Bahrain got the same HP rating as in Thailand (228)!
Could the reason be something to do with the quality of gasoline (other than the octane rating) such as impurities (sulfur etc), hence for reliability reasons Lexus playing it safe and not taking out the full potential of the engine. Just a wild guess.....
Well in Bahrain and Asia Pacific we dont have Direct Injection Cars (reason why the GS300 has 228 instead of 250.. Different Engine).. something to do with fuel quality... i've always thought that the Middle East had the best gas out there but who knows... Well Nissan cars here have MORE HP than the one you guys have :S.... A G35 is rated 330 HP here instead of the usual 303.... Lexus is the other way around
FROM WIKI:
3GR-FE
The 3GR-FE is a 3.0 L (2994 cc) version with Dual VVT-i. Bore is 87.5 mm while stroke is shared with the 2GR at 83 mm, with a compression ratio of 10.5:1. Output is 170 kW (228 hp) at 6,400 RPM, and 300 N·m (221 ft·lbf) at 4,800 RPM.
Applications:
* 2003 Toyota Crown (GRS182) (China, Asia-Pacific ex.Japan)
* 2005 Toyota Reiz (GRX121) (China)
* 2005 Lexus GS 300 (GRS190) (Middle East, Asia-Pacific ex.Japan)
* 2007 Lexus IS 300 & IS 300 C (GSE22) (Middle East, Asia-Pacific ex.Japan)
[edit] 3GR-FSE
The 3GR-FSE adds D4 direct injection. The 3GR-FSE engine is rated at 256 PS (188 kW; 252 hp) at 6,200 RPM and 32 kg·m (314 N·m; 231 ft·lbf) at 3,600 RPM.
Applications:
* 2004 Toyota Mark X (GRX121) (Japan)
* 2003 Toyota Crown Royal & Athlete (GRS182/183) (Japan)
* 2006 Lexus GS 300 (GRS190/195) (Europe & North America)
* 2008 Toyota Crown Royal (GRS202/203) (Japan)
FROM WIKI:
3GR-FE
Applications:
[edit] 3GR-FSE
Applications:
