3GS wheel thread
Old May 28, 2014 | 07:25 AM
  #1306
benztolex's Avatar
benztolex
Originally Posted by jespinoza9
Front is +25
Rear is +20
There's your issue. I think the recommend offsets are Front +38 Rear +45. The lower the offset the more your wheels with stick out which would cause rubbing if lowered.
Old May 28, 2014 | 08:30 AM
  #1307
ksan's Avatar
ksan
damn, I just got my wheels and my specs are 20x10. +30 fronts , +20 rears. lowered on BC coils. Haven't installed my wheels yet, waiting my tires.
Old May 28, 2014 | 08:45 AM
  #1308
benztolex's Avatar
benztolex
What wheels did you order? I'm not sure you about your set up since you didn't run staggered. Instead you are running a higher offset in front and lower in back. But it depends on the look you want. I wanted mine flushed closer to stock so thats why I went with those offsets.
https://www.clublexus.com/forums/gs-...-on-3gs-5.html
Old May 28, 2014 | 04:55 PM
  #1309
SLOW4DR's Avatar
SLOW4DR
what tire sizes did you order?
Old May 28, 2014 | 05:54 PM
  #1310
FrankN23's Avatar
FrankN23
Vossen VFS Satin Bronze
20x9 +32
20x10.5 + 45
Old May 29, 2014 | 03:27 AM
  #1311
ksan's Avatar
ksan
235/35/20. I got this idea from a tire suggestion through a member on here. That's what he is running and he has no issue. I did a lot of research and a lot of people that are running 245/30 or 245/35 are getting issue of rubbing on full turns and reversing I guess.
Old May 29, 2014 | 03:54 AM
  #1312
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
Originally Posted by FrankN23
Vossen VFS Satin Bronze 20x9 +32 20x10.5 + 45
looking good Frank. like that combo
Old May 29, 2014 | 06:06 AM
  #1313
SLOW4DR's Avatar
SLOW4DR
I run a 225/35 front and I rub on my liner. Depends on offset and how low you are really. A 245/30 has a a smaller tire diameter than a 225/35.
Old May 29, 2014 | 08:48 AM
  #1314
ksan's Avatar
ksan
Good to know. I just want to go low enough where this is no gap at all; probably right to the tire.
Old May 31, 2014 | 03:17 PM
  #1315
GSinTN's Avatar
GSinTN
Originally Posted by tmf2004
not sure if its the angle or what but looks like there's a slight "rake" to the stance... looks great if there is....
it was the angle of the car being parked on a slant Here's another angle of the car. It could also be i cant take legit pictures lol
Old May 31, 2014 | 03:18 PM
  #1316
GSinTN's Avatar
GSinTN
Originally Posted by aclau21
Does your rear rims stick out.
hey bud, im running megan rear camber arms to tuck my rears.
Old May 31, 2014 | 03:20 PM
  #1317
GSinTN's Avatar
GSinTN
Originally Posted by BGG
Looks good. Are you on air?
Im running the same setup w low offsets so I need to fender work to make it work
Hey bud, yes im on air and i shaved my rears and rolled my fronts so i can tuck when aired out. interested in my wheels? im thinking about getting a different setup for this summer. Im not on here often, if anything private message me
Thanks
Old Jun 7, 2014 | 06:00 AM
  #1318
ksan's Avatar
ksan
Hi guys, i was so excited to finally get my tires mounted onto my wheels. My specs are 20x10 et+30 +20 (rears). But i knew i wouldnt be that excited for long,
I went to go put the +30 upfront and it doesn't even sit on my hub, maybe only on 3 studs. I had my +20s up front just to see and it sits on the hub but scraps against the caliper. So i went to autozone, and got the cheap 5 lug 5/16 spacer and it sits fine, but it still looks very tight.. I called the vendor ive been going thru for all of this and they recommend the ichiba spacers with the extended studs on there which i think will work. But i am not local to them for me to bring in my car.
I've done so much research on my wheels and i was sure these would clear, but i guess not =(*
My dilemma is what size spacers to get for the fronts
Old Jun 7, 2014 | 12:29 PM
  #1319
Diesel350's Avatar
Diesel350
Wow you went with 10 up front? Should have gone with 9.5 or less up front.
Old Jun 9, 2014 | 05:58 AM
  #1320
ksan's Avatar
ksan
Awd,and I got a lot of feed back from guys that are running 10s up front with a lower offset then mines :/ had to be me tho that runs into this issue lol
